Seat Belt tightens up when loss of traction
Hey guys
I have a 2009 Nissan Skyline 370GT Crossover and got a weird safety feature, with
any loss of traction all the seatbelts that are active tighten up to the point of feeling like being choked.
Does anyone has that and/or know how to disable it?
Thanks
P.S my traction control is unplugged/disabled
5 hours ago, Skidmore said:
Id rather have a 4 point harness than what I have as when it tightens up its hard to steer or do anything so its more unsafe.
My experience with 4 point harnesses are they are rubbish, I would prefer the OEM 3 point.
Reason: to have it tight enough I found the lap section would pull up to my guts, sure it held me in position, but was uncomfortable, and in the event of a front end prang, I  think there's a good chance that you would end up in the foot well,  aka "submarine".
A 3 point negates this by letting part of your upper body to shift forward, 5/6 point uses your crutch area, I vote for the 6 point in this regard.
IMO you either go OEM or 6 point.
Opinions may vary
4 hours ago, The Max said:
I truly hope you're joking right now.
9 hours ago, GTSBoy said:
Bullshit.  You should not have to move your torso to steer.
Unless you're a mad gangsta low-rider
, seat back â Don Francisco by Bodega Bamz
  • Like 2
With your shoulder pushed hard into the back of the seat extend your arm ...if you can't get the heel of your palm(s) on the top of the steering wheel you are too far back to exert proper control.  People spend $$$ on bucket seats and race seats so that their bodies don't move about while throwing the car around.
  • Like 1
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
