Limits of stock 5/16" (8mm) fuel lines
We were in this position when we researched on how much the stock fuel lines can flow. With limited information, we decided to do the testing ourselves and share it with the community. As always, if you spot a mistake, please advise us and we will be happy to amend.
Author: 5-0 IGNITE
Original article from our website; https://www.50ignite.com/blog/technical-blog/article-2-pressure-is-sky-high/
Article 2: Pressure is Sky HIGH! - Flow Limits of Stock Fuel Lines main imageArticle 2: Pressure is Sky HIGH! - Flow Limits of Stock Fuel Lines image
A POINTLESS EXERCISE
#justsenditmate
Figure 1 - The boat on the dyno
Those who pondered on why we stopped at 603whp/27 psi on the project R33 GTR read on….
It wasn’t by choice, we were limited. When we built this car, we had one vision to go by; STREET DRIVEN.
For anyone who desires a go-fast-boosted street car - you will always come across the tough decision of which turbo should you go for and how important the turbo's response is. You are not at the track, you need those down-low torque or at the very least, a strong mid-range for performing street duties and occassional track days. There is no fun in it over-selecting the biggest and (inherently) laggier size turbo you could afford only to be chopped by a Honda until you hit that 6000rpm. We don’t condone street racing but the truth is, any car enthusiast regardless of age or gender will give it a squirt once in a while.
We selected a compromise of power and response on the RB26. We love our Garrett, Turbosmart, 6Boost, Tomei and Haltech products. Looking at very few compressor maps on Garrett GTX Gen 1 turbos (this was 2016 mind you) and drawing lines based on flow and pressure ratio to find the right efficiency on ‘What if’ power level, we settled on the GTX35R with 1.06 twin scroll rear housing. This turbo was chosen after much discussion and thought, we concurred that it won’t be too laggy of a turbo setup and should yield about 650hp at the wheels on the small but mighty 2.6L.
From there onwards, a forged internals build started and supporting mods were chosen; 6Boost twin scroll manifold, Plazmaman intercooler, Tomei cams, Turbosmart fuel regulator, Turbosmart external gate, Turbosmart BOV, Bosch motorsport injectors, 3 Walbro 460lph fuel pumps (1 lift and 2 feed, in parallel configuration) for E85 and so on and so forth.
We had a stop to think, with this much fuel feeding the beast, how much can the stock fuel lines be able to cope? Can it flow enough to match the fuel delivery?
The answer to that question at that time was simply #YOLO (we don’t have Instagram by the way) and #justsenditmate. Information on the internet as to “how much does 5/16” (8mm) fuel line can flow at xx pressure” was sketchy at best and inputs from the forums were a pure guess based on “my dad’s friend’s uncle’s setup” etc. Nothing was solid or backed with numbers, so we thought that it would be a good opportunity to see how much indeed stock fuel lines could flow and answer the question for the world.
During the last tuning session at WTF Auto, Tristan dialled in 30 psi on the Haltech. The dyno session stopped not long after, as fuel pressure dropped the moment we hit full boost. We re-checked the fuel pressure at the FPR and checked the fuel pressure at the fuel pump outlet. The pressure at the FPR was 55psi base, exactly to how it was set, but the pressure at the pump outlet was 90psi. That is a shocking 35psi pressure drop across the hard lines! The over-pressure relieve valve on the Walbro 450 LPH is set at 120psi from factory, so if we are sitting at 90 psi base pressure on the fuel pump outlet and we add 30psi of boost to the system, quick math shows 90+30=120 psi - all adds up to trip the relieve valve. This is why fuel pressure dropped the moment we hit full boost at 30psi.
Figure 2 - Power limit before stock fuel lines can't handle
If you have read this article this far, congratulations! Because we are about to bore you even more!
To understand what was going on, we needed to do some quick measurements and look at fluid dynamics.
It is somewhat valid to some degree to assumed that most Japanese cars that run 5/16” (8mm) outside diameter fuel line (bar the soft lines). Fluid flow and head (pressure) losses can be contributed by major and minor losses in the system;
Major loss - Head losses due to friction within the pipe affected by flow velocity, pipe length, pipe diameter, pipe surface roughness and the viscosity of the fluid being transferred.
Minor loss – Head losses due to friction and flow disturbances within the system affected by components such as couplers, entry condition, bends, valves, filters, diaphragm etc.
To keep things simple, we analysed the major losses in the system only as it will always be the predominant cause of pressure loss. With different fuel system setups differing from car to car and the type and number of fittings used, the minor losses cannot be determined accurately without physical flow testing.
Since we are running the 2 feed pumps in parallel, the theoretical flow rate is just compounded. Remember, pressure is a resistance to flow.
Figure 3 - Walbro 450 LPH performance chart (Walbro 2018)
Analysis of the friction factor for turbulent flow inside a smooth wall pipe using Moody chart;
(S. Beck & R. Collins, University of Sheffield 2018)
From the two intersecting lines above, we can find that the friction factor is approximately 0.048.
Conclusion
The theoretical, calculated value for the pressure drop of 31.5 psi strongly correlates to the 35 psi observed on the vehicle. Bear in mind, that only major losses are calculated, safe to say the remaining 3.5 psi drop can be attributed to minor losses in the system.
So, how much flow can the stock fuel line take without too much pressure drop? Well, it highly depends on what you define as "too much" pressure drop. We set an expectation that the fuel system should not have more than 8 to 10 psi drop between the fuel pump outlet and the regulator. Working backwards with the equations above in the instance of running the same Walbro 450 LPH, we find that the maximum flow rate shall not exceed 0.000066 m³/s (238LPH). This is equivalent to running a single Walbro 450 LPH pump at 95 psi!
Moving forward, the next step is to upgrade the fuel lines to AN -10 size (~12.7mm internal diameter) and increase the boost to 35 psi (however, we expect that the turbo will run out of steam before this). The base fuel pressure will remain at 55 psi with the two existing pumps blazing and the fuel pressure at the regulator, at full boost, should be at 90 psi. At that pressure, the twin Walbro pumps should be able to flow 536 LPH (0.000149 m³/s) with a pressure drop of approximately 1 psi due to major losses. Minor losess within the system should also decrease as all the fittings and liners in the vehicle will be converted to AN -10.
References
Curtin University. 2015. Fluid Mechanics 433 Course Notes - Lecture 1. Perth.
S. Beck & R. Collins, University of Sheffield. 2018. Moody Chart. 26 07. Accessed 08 29, 2018. https://en.wikipedia.org/wiki/Moody_chart#/media/File:Moody_EN.svg.
Slurry Pipes. 2018. Pipe Roughness. 29 08. Accessed 08 29, 2018. http://slurrypipes.com.au/properties/low-friction/.
Walbro. 2018. Walbro F90000267 Performance Chart. 29 08. Accessed 08 29, 2018. https://walbrofuelpumps.com/walbro-f90000267-fuel-pump-e85.
  • Like 5
  • Thanks 1
Baffled with science.  Not quite sure what to conclude from your testing. Most people run 18 to 25 psi and want to know how much power they can achieve before having to change fuel lines. Anyone  building a serious drag car or a drift machine where they will spend a lot of time at WOT  will probably change the fuel system as a matter of course.
Ahh yes. Anybody building a serious track weapon would upgrade more than just the fuel lines. Majority of the owners have their car street driven and upgrading fuel lines to a bigger one whilst keeping road worthy could be a challenge and expensive. How much boost you run is important on selecting the right fuel pump for your application (making sure it can flow at xx psi) but not to sizing the fuel line. To keep it simple;
- From the above, we determined that the maximum flow is 238 LPH with approximately 8.5 psi pressure drop (it can flow more but with significant pressure drop).
- 238 litres per hour is 3967cc/min.
To have a rough estimate on how much power it can handle on the 6 cylinder application, we apply the rule of thumb just like how we size injectors. 3967/6 = 661cc/min. For typical 6 cyl, 660cc injectors can normally output 660hp at the wheels on 98 RON.
  • Like 2
Wow! Thats awesome information, tried to guestimate/calculate the same thing when I refreshed my fuel system, but it ended up a bit low compared to the real numbers you found! Attached image is of stock fuelrail inlet/outlet vs AN8 fitting... Notice the sharp and narrow left connection?
Got myself some AN8 lines in the end, should be enough for me and my 530 LPH pump :)
Edited by K_arlstrom
  • Like 1
If you are running -8AN all the way (~9.5mm inside diameter), with flow of 530 LPH, the approximate pressure drop would be 4.5 psi. This will be reduced if you are running teflon hoses or reduced the total length.
Teflon hoses and as straight and short as possible aluminum pipe. Fuelab 41402 pump, dont know what gallons they used in the attached chart, but it should suffice any day of the week ? (got a vision/goal of everything being able to handle 500 awkw on E85)
My rough calculation told me I would end up with a 3 psi drop, but anything below 5 feels acceptable. Someone should sticky this thread :)
  • 6 months later...
I'm making 500awkw on e85. stock fuel lines, stock nissan fuel filter, stock rail, tomei type-L and bosch 1650s.
single in-tank pierburg L3LM @ 17.5v (boost-a-pump), range rover PWM pump controller and an aftermarket fuel hat. holley hydromat on tank floor.
very efficient pump at high pressures. can only just hear it prime before starting the car. once engine running its effectively silent.
not sure on pressure drop but don't care either. ECU uses injector delta pressure in model.
Edited by burn4005
  • 2 years later...
As someone who has dealt with fuel system issues over the years, I thought I'd bump this information. A lot of people should read this as it answers a lot of questions regarding fuel system setup.
  • Like 2
 Share
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
