So I recently bought a 1998 r34 gtt coupe and it wasn't perfect but I'm fixing it up and I've pulled the center console out to give it a clean and found this loose wire that i have no idea what it was for. Does anyone have any ideas?
It's the grey one underneath the handbrake connected to the red quick connect terminal
https://www.sau.com.au/forums/topic/474835-what-is-this-wire-r34/
Not what but who. That's Jim the party wire, don't let his plain grey appearance fool you, and don't leave any alcohol in the car.
Does it tie into one of the wires connected to handbrake? If so, prob for a turbo timer.
Cheers to the people who actually contributed rather than just posting to feel superior
Yes it does go to the handbrake and the more i look at it the more i agree it's for a turbo timer. I've never had much experience with them so can't really say much but i appreciate the help!
3 hours ago, hardsteppa said:
on worries.  Splices in there cos meant to stop car running away on the turbo timer if handbrake is not on.
FYP
Wonder why they painted the tray yellow???  Rust maybe???
No worries.  Splices in there cos meant to stop car running on with turbo timer if handbrake is not on.
So the turbo timer won't work if you don't put the handbrake on?
35 minutes ago, tridentt150v said:
FYP
Not too sure what part exactly you're talking about but the car is yellow and has never been resprayed. I doubt the console has ever been taken off seeing as i found McDonald's chips down there (not sure what's more disturbing, the fact that they were there or the fact that they still looked okay)
1 minute ago, GTSBoy said:
Anti-theft.  Stops the engine as soon as thiefy drops the handbrake.
It's got power as soon as the ignition turns out but I'm not sure if it's only while the handbrake is on or off as well. Anti theft doesn't seem like the answer as anti theft would likely need power even when ignition is of
2 hours ago, Ljbyrne98 said:
i didn't realise the anti theft and the turbo timer were attached
I didn't say that the TT and the alarm/immobiliser were attached.  What I said was that a thief cannot drive a car running on its turbo timer away, if it will stop as soon as he releases the handbrake.  The TT accepts a signal from the handbrake wire as an interlock.  That's all.
Correct.
Interesting cos my '98 R33 has the grey lacquer type [not sure what the correct term is] finish to all interior metal parts....
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
