Hi guys,
I don't drive my R33 GTR often but this morning started noticing that my car's RPM gauge (stock factory) is acting funny in the sense that it would sometimes get stuck at 5,000 RPM and then not rev over that and then come back down again and then sometimes it spins up and down a few times and resets to 0 again.
I don't think it's a mechanical or engine issue and my car drives normally but perhaps it something to do with the gauge or the wiring itself?
Has anyone experienced this and how did you fix it? Thought I'd check here first before taking it to a motor mechanic.
Cheers,
Alex
5 hours ago, niZmO_Man said:
I think I've read about R33's having crazy tachos, you'll have to pull the cluster out.
Did you have a wonder through the search results here?
Hi mate,
I too heard about this - it's very weird as the car runs normally so probably just the Tacho going spastic.
Tried searching with no luck unfortunately.
Cheers,
Alex
Tacho runs from an ECU output.  Check appropriate pin in the ECU plug is in good order (inserted properly, not broken, dirty, etc).  Hook oscilloscope up to that pin and see if the ECU output is clean and proper.  Try again at tacho end of wiring and see if it's clean there.
Much appreciated mate. I'll give it a go soon.
Cheers,
Alex
Hey mate, you're a life-saver. Much appreciated.
So if I don't really care about the Rev cluster for now as I'm too busy leaving it as is won't harm or damage my GTR in anyway, would it? Seems to be a fairly complex skills fix and  requires a lot of time to take the dash apart both of which I do not have.
Once again, many thanks.
Edited by Robocop2310
On 9/7/2018 at 4:35 PM, iTzTMG said:
You're welcome mate.
Taking the cluster out is not too bad, the soldering part does require some skill but it won't do any harm if you leave it as is.
You're spot on mate. I've taken the cluster out before to change blown dash globes so it's not too bad but the soldering part I'm stuck so guess will leave it as is for a while until I have time to bring it to mechanics. Once again, much appreciated mate.
  • 1 month later...
3 hours ago, CU's GTR said:
There is a place in Ringwood that fixed that issue. For $120 they change and fix the cluster. They are on Maroondah hwy near the east link.
Many thanks mate. Would you know the name of this place by any chance?
Cheers
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
