Hello everyone!
After stupidly having my Gt-r sitting in the garage doing nothing for about 2-3 years I’ve tried to give it a run. I changed the oil and oil filter and tried turning it over with no success (surprise surprise). My battery is fine and it’s got fresh fuel.
As I turn it over I don’t get any oil pressure on the gauge, is that expected? Will I only get pressure once it starts? Bit of a noob tbh. I’ve read that the gtr oil pressure sensors are dodge city, could that be stopping it from starting?
Im going to check for spark but I’m worried it’s full of sludge. Can anyone point me in the direction of a good mechanic in Sydney’s south?
Any help is appreciated!
Thanks!
https://www.sau.com.au/forums/topic/474870-gtr-won%E2%80%99t-start-help/
Shouldn't see oil pressure on gauge while cranking.  Is the fuel pump priming and stopping like it should when you turn on the ignition?  If not, could be dead/seized from inaction.  Injectors could also be stuck closed.  Does it fire in any way at all, or just cranking with no chugs?
Ok cool, that’s a bit of a relief at least. Yeah the fuel pump primes when I turn it on reds as expected. Doesn’t sound like it’s firing, just cranks on the starter motor, I need to check for spark right? Does the ecu rely on the oil pressure sensor to start? I also thought it could be the ignition module since that’s gone on me before but after buying a new one I tested my old one and it was fine (face palm).
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
