Hey All,
Any help would be much appreciated! Im new on here so im sorry if this is the wrong place
I am looking at purchasing a new set of Panasport G7 c5c2, they are odd sized so im not too sure about the inner guard clearance.
Fronts: 17x9 +22
Rear 17x10 +42
I have used willtheyfit.com to find out that the poke on the front is slightly more than the rear.
Main questions are, will they fill the guards? and will they clear the rear coilovers? has anyone fit this sized wheel before?
Can anyone also confirm the difference in guard clearance on an R32 gtst coupe? because it seems everyone likes to run staggered wheels with larger on rear?
Any help on this would be awesome!
Cheers,
Dan
I don't think your sizes will fit.  10" on the rear is essentially impossible on an R32 regardless of offset.  (Ignoring spacers, guard modifications, etc).
Anything bigger than 8.5" on the front is really pushing it too.  I have 17x8" +35 all around.  If I could find a workable offset, I could probably get an 8.5 in there without it rubbing on things, but as it stands, there is almost no clearance when the wheels are turned to the plastic liner and various other spots.
On the rear, I'm sure I could fit a 9" wheel, maybe even 9.5, again with the ideal offset.
Look at the very informative wheel fitment thread in this very forum to see what people have managed and what stupid amounts of camber they may have had to run to squeeze it in!
Thanks for reply @GTSBoy
I had a feeling this was going to be the feedback  , really appreciate you giving me that. I will have a look through the thread and see if I can find any similar offsets or sizes.
They are just really nice wheels and I wanted them to fit
Edited by furlongvia
30mm bolt on spacers
-5deg camber all round
185 wide tyres
do it
jokes don't
Sounds like those wheels are for a Supra or something (Toyota tends to run higher offsets).
For reference: early Nismo sizes were 7.5 +35/8.5 +38 or something like that, but you could get away with going half an inch wider.
I have a set 17x9 + 20 on my 32 gtst.
They will fit, and they won't hit the coilovers, but you will NEED to remove the inner guards, roll the guard edges, run a bit of camber and I run 235/45 tyres which are a little less than ideal width.
I've tried to set mine up with the least amount of camber necessary to keep the wheels a) inside the guards and b) avoid scrubbing, from memory fronts are around 2 - 2.5 on the front and around 1.5 on the rear.
I'm currently looking to swap these wheels out for something in the 17x8 range though to make things a little more practical.
  • 1 month later...
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
