Hi people,
I'm looking for an r33 gtr hicas wiring harness/ plugs and hicas motor relay to do an electronic hicas conversion on my r32 gtr. I have tried all of the skyline/jap spares and wreckers I could find and haven't had any luck, if anyone on here knows where I might be able to get one or has one, it would make the project a lot easier and make it a lot neater. I have everything else ( r33 gtr hicas ECU, yaw sensor, rack assembly, clock spring and a good set of wiring diagrams which I have already cross referenced to the r32 diagram to make it work).
Any info or help would be appreciated.
Thanks ?
https://www.sau.com.au/forums/topic/474904-r33-gtr-hicas-into-r32-gtr/
Hi people,
Thanks [emoji16]
Why do you want hicas?
  • Like 1
  • Haha 1
Why not? I know alot of people take it out because they dont like how it feels, cant repair it properly or just because everyone else did it. But once you learn what it's doing and how to drive with it in the car its great. The r32 system is just a bit crude and not nearly as refined as the electronic system and I thought while the car is off the road I would take the time to make it better.
  • Like 2
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
