Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
Nothing, except the Quaife rear diff centre of course. Bolts up to any GTR driveshaft axles, except R33 and R34 v spec active diff shafts as they are shorter. Any GTR non active diff driveshafts will bolt up, correct length. This is my spare set I don't need and used same setup. Installed it on my 32 earlier this year when I put Quaife front and rear diffs in.
So the diameters of the shafts are the same and will just fit into the old 32 housing no problems?
Who did you use to install the diffs? If you dont mind me asking, since Award is no longer.
There is a 1mm diameter increase in non splined shaft area from 32mm (30 tooth) to 33mm (31 tooth) and 1mm approx. increase in diameter on spline from 30.9mm (30 tooth) to 32mm (31 tooth). No problems with housing clearance as the increase is all to do with the diff centre bigger spline change. The speed sensor 46t outer and 6 x 1 flange pattern and dimensions are the same.
My father who is a mechanic and has his own workshop did the diff install. Don't have the luxury of 100s of workshops here in Alice Springs like on the east coast. He's pretty much the resident RB26 / GTR guru here in town. Not a lot he doesn't know about them or how to work on them. He is the assembler of the OS giken box for sale here also.
Full genuine Nissan RB26 exhaust / turbo side gasket set - SOLD
Tomei RB26 metal exhaust manifold gaskets - SOLD
  • 4 weeks later...
  • 3 weeks later...
Nismo thermostat - SOLD
Nismo radiator cap - SOLD
Tomei block restrictor - SOLD
ATS clutch discs and pressure plate sold pending payment.
31t rear half shafts sold pending payment.
All PMs replied to.
Fresh 10 plate (standard is 7) modified transfer case is now completed and up for sale. Like new inside and reset back to factory new tolerances. New drive / friction plates, new strainer filter, new oil pump o rings, new retaining and pressure plates, shimmed back to factory 0.2mm - 0.5mm (8 - 20 thou) drum clearance as per required tolerance (around 13 thou from memory).
$1500
Just added for sale Trust / Quaife 3F1 6 speed H pattern straight cut dog box with freshly modified transfer case added for sale.
$8500 ONO shipped anywhere (possibly throw a clutch in there with it with the right buyer).
Going sequential so not needed - make and offer !
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
    • Kicked the 34 in the guts, she won’t be seeing the road till I get the 31 mobile again.  wont be long and she’s a bit of a garage princess anyway haha
