Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
Ross R32 GTR balancer - SOLD
Added for sale:
Brand New R32/33 GTR 31 tooth rear diff half shafts. Last set ever - $900
Used Tomei type B valve springs and retainers RB26 -$400
Added for sale:
6 x Sard / Denso 1000cc injectors - $600
HKS T51S 1.00 A/R Turbo. Comes with T4 to HKS 99.1mm V-band manifold flange adapter - $1500
Push bearing carriers 14mm, 18mm and 26mm - SOLD
R33 GTR standard ECU sold pending payment.
Modified R32 / R33 GTR transfer case sold pending payment.
  • 3 weeks later...
31 tooth rear gtr half shafts - SOLD
Added for sale:
Used HKS EVC III boost controller complete - $250
Used HKS EVC IV boost controller complete - $290
Used Trust oil cooler 13 row core with AN10 tank fittings - $220
Brand new 40psi electronic 60mm JDM dual analogue / digital 40psi display boost gauge with MAP sensor and mounting cup - $220
If anyone needs a 10 clutch transfer case upgrade ($1200 including parts) or OS giken gearset build ($1400 labour only. Can supply all parts if needed.) can do as well. 2 - 3 month lead time. Shipping to and from obviously extra.
I'm away for work right now but will post up turbo pics on Saturday when I'm back.
Tomei type B valve springs and retainers - SOLD
Nitto RB head drain - SOLD
Nitto 2.8 billet 77.7mm stroker crankshaft sold pending payment.
  • 4 weeks later...
Nitto billet 2.8 crankshaft - SOLD AND GONE !
Oil cooler sold pending payment, read again, PENDING PAYMENT ! Still for sale until that.
I will get turbo and 1000cc Denso / Sard injector pics up soon.
Also have NEW 6 x Bosch full length injector adapters for sale 11mm rail  - $80 posted
60mm boost gauge with remote mount MAP sensor 1.6BAR. Remote mount peak / hold setting controller. Boost gauge without pressure in cabin ! Comes with 60mm gauge cup too ! - $110
New photos !
NEW R34 GTR lower shifter bushes - $10
100mm turbo bell mouth. Anodised blue - $80
HKS EVC III boost controller complete with instructions. Max 2 bar boost. - $270
HKS EVC IV boost controller complete with instructions. Max 2.5 bar boost. - $290
6 x 1000cc low impedance 1000cc Denso / Sard injectors. 0.85ms lag. Denso high guide plug type. - $700 FIRM
1.6 bar electronic boost gauge with 60mm mount cup and peak / hold controller. No boost lines into cabin. - $110
NEW 6 x Golebys 11mm Bosch injector adaptors with o rings. Full length.  - $70
HKS T51S 1.00 A/R turbo pics tomorrow. - $1500 ono
  • 4 weeks later...
  • 1 month later...
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
