Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
Ross R32 GTR balancer - SOLD
Added for sale:
Brand New R32/33 GTR 31 tooth rear diff half shafts. Last set ever - $900
Used Tomei type B valve springs and retainers RB26 -$400
Added for sale:
6 x Sard / Denso 1000cc injectors - $600
HKS T51S 1.00 A/R Turbo. Comes with T4 to HKS 99.1mm V-band manifold flange adapter - $1500
Push bearing carriers 14mm, 18mm and 26mm - SOLD
R33 GTR standard ECU sold pending payment.
Modified R32 / R33 GTR transfer case sold pending payment.
  • 3 weeks later...
31 tooth rear gtr half shafts - SOLD
Added for sale:
Used HKS EVC III boost controller complete - $250
Used HKS EVC IV boost controller complete - $290
Used Trust oil cooler 13 row core with AN10 tank fittings - $220
Brand new 40psi electronic 60mm JDM dual analogue / digital 40psi display boost gauge with MAP sensor and mounting cup - $220
If anyone needs a 10 clutch transfer case upgrade ($1200 including parts) or OS giken gearset build ($1400 labour only. Can supply all parts if needed.) can do as well. 2 - 3 month lead time. Shipping to and from obviously extra.
I'm away for work right now but will post up turbo pics on Saturday when I'm back.
Tomei type B valve springs and retainers - SOLD
Nitto RB head drain - SOLD
Nitto 2.8 billet 77.7mm stroker crankshaft sold pending payment.
  • 4 weeks later...
Nitto billet 2.8 crankshaft - SOLD AND GONE !
Oil cooler sold pending payment, read again, PENDING PAYMENT ! Still for sale until that.
I will get turbo and 1000cc Denso / Sard injector pics up soon.
Also have NEW 6 x Bosch full length injector adapters for sale 11mm rail  - $80 posted
60mm boost gauge with remote mount MAP sensor 1.6BAR. Remote mount peak / hold setting controller. Boost gauge without pressure in cabin ! Comes with 60mm gauge cup too ! - $110
New photos !
NEW R34 GTR lower shifter bushes - $10
100mm turbo bell mouth. Anodised blue - $80
HKS EVC III boost controller complete with instructions. Max 2 bar boost. - $270
HKS EVC IV boost controller complete with instructions. Max 2.5 bar boost. - $290
6 x 1000cc low impedance 1000cc Denso / Sard injectors. 0.85ms lag. Denso high guide plug type. - $700 FIRM
1.6 bar electronic boost gauge with 60mm mount cup and peak / hold controller. No boost lines into cabin. - $110
NEW 6 x Golebys 11mm Bosch injector adaptors with o rings. Full length.  - $70
HKS T51S 1.00 A/R turbo pics tomorrow. - $1500 ono
  • 4 weeks later...
  • 1 month later...
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
