Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
Sold pending payment:
NEW R32 GTR genuine Nissan Pitwork power steering belt 4PK950
NEW R32 / R33 GTR lower gearbox shifter boot
Used R33 GTR genuine rear upper control arms
Used R32 GTR genuine rear upper control arms
NEW R32 GTR genuine Nissan Pitwork power steering belt 4PK950 - SOLD
NEW R32 / R33 GTR lower gearbox shifter boot- SOLD
Used R33 GTR genuine rear upper control arms - SOLD
Used R32 GTR genuine rear upper control arms -SOLD
TRUST OIL COOLER SOLD PENDING PAYMENT
Trust oil cooler - SOLD
1000CC Denso injectors sold pending payment.
Also now up for sale:
6 X Bosch 2000cc injectors with 14mm adaptors - $400
BPP twin entry 14mm fuel rail - $250
Link G4 plug in GTR ECU - $1500
Make an offer, everything is always negotiable...
  • 1 month later...
SARD / DENSO 1000cc injectors - SOLD
ARP RB26 main studs - SOLD
Used RB26 crankshaft lower timing belt gear - SOLD
R32 RB26 water pump - SOLD
R32 coilpack harness - SOLD
Added for sale:
Camtech CT3536/37 445B R32 / R33 RB26 inlet / exhaust camshafts - 272 deg. 9.7mm lift. Trial fitted only. - $850
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
Price update:
Rb26 Lower timing belt steel cover - -$50
R32/R33GTR Upper timing belt cover -$400
Camtech cams as mentioned above -$750
Rb26 BPP 14mm twin entry fuel rail -$240
HKS turbo - $1300
R32 GTR standard coilovers with lowered springs -$400
First page availability updated.
  • 5 weeks later...
OS88 solid shifter - SOLD
HKS EVC III boost controller - SOLD
HKS EVC IV boost controller not sold due to some people being dropkicks on here. Back up for sale.
Added for sale:
Used Nissan RB26 90A alternator - $150
Used Turbosmart FPR800 adjustable fuel reg in blue - $170
Used Nismo BNR32 front upper control arms with Nismo reinforced bushes - $330 - excellent condition
Used standard R32/R33 GTR blow off valves - $150
Photos added.
Standard R32 GTR coilovers
R32 GTR Nismo Front upper control arms
Turbosmart FPR800 adjustable fuel regulator
OEM RB26 cam gear cover sold pending payment.
Camtech 272 cams dropped to $650. Come on, someone must need some wild cams....
  • 3 months later...
  • BK changed the title to RB26 GTR parts- HKS T51 turbo,RB26 crankshaft,Prosport 40psi boost gauge,BPP twin entry fuel rail,R32 GTR stock coilovers,RB26 OEM head gasket, Turbosmart FPR800 fuel reg,BNR32 front arms, R32/R33 GTR blow off valves
  • 1 month later...
Camtech 272 camshafts - SOLD
This makes me a bit sad really as I'll never get them again since they've shut up shop. 😔
Hope they work out well and make that RB26 rev ☺️
  • BK changed the title to RB26 GTR parts- Modified R32/R33 RB26 GT-R transfer case,HKS T51 turbo,RB26 crankshaft,Prosport 40psi boost gauge,BPP twin entry fuel rail,R32 GTR stock coilovers,RB26 OEM head gasket,Turbosmart FPR800 fuel reg,BNR32 front arms,R32/R33 GTR blow off valves
Just completed -
Modified 10 plate R32/R33 RB26 GT-R transfer case added for sale. - $2100
Was going to be my spare
  • BK changed the title to RB26 GTR parts- Modified R32/R33 RB26 GT-R transfer case, RB26 crankshaft ,Prosport 40psi boost gauge,BPP twin entry fuel rail,R32 GTR stock coilovers,RB26 OEM head gasket,Turbosmart FPR800 fuel reg,32 front arms,R32/R33 GTR blow off valves,GTR front diff
  • 2 months later...
  • 7 months later...
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
