Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
On 26/5/2021 at 10:20 PM, BK said:
GTR front diff - SOLD. Second unit still available.
HKS turbo sold pending payment.
Hey mate,
what ratio front diff do you still have? After 4.11.
Thanks
Hi mate. Front diff centre only, not with crown wheel and diff pinion so you can fit whatever crown wheel ratio you want to it.
I have 1 spare set of 4.11 front crown wheel and pinion but keeping it as they are worth a fortune now and have broken them before.
On 22/06/2022 at 8:45 AM, Milhouse said:
Ok thanks but you are right - only after a 4.11 crown wheel and pinion as mine is worn out...
What diff oil you running ? Needs to be 75w-140 or this will always happen eventually.
Can’t remember exactly but wear would have come from previous owner as car had 115k on it when I got it. My diff workshop asked the same question so oil seems to be quite important in these diffs.
Have been looking for a decent cond ring and pinion now for a number of months but looks like I have finally secured one today so fingers crossed!
  • 5 months later...
Time to do an end of year update of things for sale:
Precision ball bearing Gen1 6266 turbo T4 divided 0.84 a/r SP cover - requires rebuild on chra, Slightly passing oil but will smoke if used, otherwise ok. Can be rebuilt locally by Rose rage turbos or sent back to Precision - $1100
Trust T78-29D turbo, T4 divided - requires rebuild on chra. Same as above passing some oil on seals. Easy to rebuild with genuine Mitsubishi parts - $900
NPC 10" single plate push clutch rated to 450kw. NPC7056B-10 Good condition, suit all RB push setups - $700
New in box Turbosmart OPR T40 turbo oil supply pressure regulator - $140
RB26 R33 flywheel - $200
NEW Prosport 60mm dual stepper motor type JDM series 40psi electronic boost gauge with pressure sensor, harness and 60mm gauge cup. Has dual analogue needle and digital readout, programmable warning light. - $220
Used BPP 14mm twin entry fuel rail, anodised black, no mounting spacers - $150
Used Nissan RB26 90A alternator - $150 (maybe I should keep this...)
Used standard R32/R33 GTR blow off valves - $150
Used Turbosmart FPR800 adjustable fuel pressure regulator in blue. Fitted with AN6 male flare inlet and 5/16" hose barb outlet fittings - $150
Used BNR32 front upper control arms - $150
Used RB26 lower front belt timing cover like new - $60
2 X New RB26 genuine NIssan head gasket 11044-05U16 - $90 each (rrp $130)
Used 60mm electronic boost gauge, 1.6bar max with MAP sensor. 60mm gauge cup included. Remote peak / hold controller - $90
3 x R34 GTR lower shifter bush - $10 each.
Used R32 / R33 GTR pull clutch slave cylinder and hose - $90
Used Rear R33 GTR sway bar - $90 (Good S14 or S15 upgrade)
NEW R33 GTR / GTS25T STS Performance (made in UK) 3 ply silicone lower radiator hose in RED from GCG turbos (not chinese ebay crap) - $45
Used R32 GTR front diff centre - $200
USED R33 RB26 LONG NOSE CRANK, unknown condition, has surface rust - $500
Carbon fibre N1 bootlip spoiler -$250
FRP N1 bootlip spoiler in TH1 blue - $200
Used Bosch 044 fuel pump - $100
Used SARD / DENSO 1000cc injectors. Low impedance , 0.85ms latency. Fit 10.5mm (standard) or 11mm fuel rail. - $400
Tomei sump baffle kit - $150
More to come when I think of it
  • BK changed the title to Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
