Hey fam,
So yesterday I changed my cluster and as soon as I started the car I had an engine light that wasn't there. The globe still worked in the old cluster so it's not like the light was there the whole time. My question is, is the engine light due to changing the cluster or something unrelated?
TIA
https://www.sau.com.au/forums/topic/474953-engine-light-on-r34-cluster-change/
Sorry, I thought I was pretty clear. It wasn't there but showed on start-up as it should. Once I changed the cluster it was there permanently. The question is does changing the cluster cause the engine light. I'm thinking maybe if it's related to the change of cluster then it's a way to prevent people changing the clusters to wind back the Kms but I've never heard of this before
If you are referring to the engine warning light have a search and find how to get fault codes on your car and go from there. Or disconnect the battery and reconnect to see if it disappears.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
