1 hour ago, burn4005 said:
Yes, I think that's now accepted wisdom. The point of this thread is to show some evidence as to what is happening, and how bad it actually is.
I could put up if owner allows the end effect on knock and ign advance, we are talking 'allot' at 8000rpm and on-wards.
You also see it graphically when trying to run a VR sensor on a single tooth on the cam, it can trigger errors due to the slap in the belt (again if your ECU reports this?), its one of the easiest way just do a sync capture and check the wave pattern, it is horrendous !
So you go from running maybe your target ign timing on one cylinder at one cycle and could be out multiple crank degrees on another cycle, and again on a top quality knock control system you will see this as we did, change out the ghetto trigger system and much more safety and much more power is to be had ;)
I'm not as smart as most of the people in here commenting but i do have a question, the 'sync position' on the Emtron is that just a measurement how far out of alignment the cam 24+1 'sync/home' signal is with the crank based 'ref/crank'.
Is it comparing the 'sync/home' trigger event to the same 'ref/crank' trigger event every time? If so then even though the update speed is nowhere near the same as the crank based pickup it should still give a good indication of how much variation is being induced in the cam driven setup correct?
Also what is the accepted 'minimum millisecond pickup time per tooth' for a high revving engine such as an RB? There seems to be such a large spread available especially in OEM form (Evo having 2 crank teeth and LS having 60-2) yet all engines seem to run fine. But in the skyline aftermarket world people will argue anything from 6 - 60 teeth on the crank are required. Looking through your maths @burn4005 it seems that 5deg/tooth @ 8000rpm = 0.000391ms is an absurdly small amount of time it could be considered overkill. I understand that if your hardware (ECU and crank pickup assy) is up to the task the more finite the triggering the better, but i guess my question is what is the minimum amount of teeth required to result in smooth engine operation and effective and reliable ignition timing (not needing individual cylinder knock control like RICE is talking about)
that is correct,
the sync signal occurs only once every two revolutions of the crank, and the edge of it occurs between the same crank teeth on every sync event. the edge always occurs in the 10 degree window between 300 and 310 (of the crank wheel), so it drifts around by a few degrees. so what you end up seeing is the cyan trace moves slightly to the left and right as the belt stretches/cam to camshaft coupling wobbles.
This is why when you get to high tooth counts (60 tooth wheels) you always run a missing tooth on the crank so the reset is done based on that, as if you don't have a missing tooth you are telling the ecu to do the reset on the next crank tooth after a sync signal. and if that sync is wandering by 4/5 degrees you're in danger of the ecu taking the wrong crank tooth as the crank reset. with 12 tooth crank, the gap is plenty wide (30 degrees) so you can be sure the sync will always occur between the same teeth.
the upper limit of time per tooth depends on the response of the sensor (my crank sensor (ZF GS101205) will do 15khz under ideal conditions, the only other limit is how small a resistance you use for the pullup. (15khz is 75000rpm on a 12 tooth crank, or 15000rpm on a 60 tooth crank) the falling edge is always very steep as it is a low impedance short to ground by the sensor (open collector) and thats why you should always use it as a trigger edge as it is much more consistent. The rising edge starts to look like a shark fin as it takes some time for the voltage to rise again after the short to ground stops. A 1k ohm pullup will rise much faster than a 4k7 pullup. so at very high speed it might not make it all the way to 5v before the hall triggers again.
Shark fin:
Image result for shark fin pullup resistor
In a good ECU this isn't a problem as you can set the trigger voltage threshold, so as long as the trigger signal rises to say 2.2v, then falls to 0 it is counted as a trigger event. I am using the internal 4K7 pullup in the emtron and don't have a problem at 8800rpm, I scoped to to confirm voltage rise was fast enough to get well beyond my 2.2v threshold, otherwise I would have used a 1k external pullup instead.
the earlier sensors (GT101 etc) had an issue with the Schmidt trigger design which is required so the hall effect trigger thresholds are self adjusting. So if you had missing teeth it could cause issues as there was a very sudden change in event spacing time. the newer sensors (like my ZF one) don't have this issue. its also very important to have as small an air gap as you can to force the hall effect voltage hysteresis gap size in the sensor to be much wider, which also helps to avoids false trigger events. mine is only ~0.4mm from the trigger teeth. If you have a large air gap, it is a weaker signal so the Schmidt trigger needs to be more sensitive so you have a larger chance of false trigger or missed trigger events.
Hall sensors are fine, as long as your tooth pitch (spacing), height  and depth match the requirements of the sensor. the more teeth, the bigger diameter you need.
a company called Spectec make extremely high performance hall sensors that can cope with tiny tooth pitches where a Cherry just wouldn't reliably pick up teeth. (like trying to make a 36 tooth hi-octane style kit)
a VR sensor doesn't have any of these issues, and the faster the trigger wheel goes the better the signal to noise ratio gets as the signal amplitude increases. it also crosses zero as the trigger point which provides perfect accuracy, rather than an arbitrary 2.2v which isn't as precise as you're relying on "catching" a falling edge that isn't perfectly vertical.
Edited by burn4005
  • Like 1
Thanks for the excellent in depth response. I understand that you have to match the frequency response of the sensor to the tooth frequency/RPM of the crank to ensure everything is operating within its correct parameters, but my question is still what would you consider the minimum teeth on a crank trigger wheel to give effective triggering on an RB?
What exactly is the crank trigger kit you are using?
on an RB26 12 teeth is plenty as it is operating at high speed when ignition timing is important ( and at high speeds the errors are less) under boost/load 1 degree makes a magnitude more difference than under vacuum). it depends how important rock solid idle timing is to you (we are talking ~1-2 degree error though).
on a slow revving, high torque high compression engine (diesel for example) where the power strokes are slow and strong you would want more teeth. 36+
I went a 36-2 as i like the engine starting one crank sooner and my engineering OCD got the better of me.
my kit came from JHH racing, they weld either a 12 or 36-2 wheel to a 1000hp ATI balancer and supply a sensor and bracket that bolts to oil pan flange. excellent bit of gear.
Edited by burn4005
36-2 with VR on crank here and HALL on phase (cam) single finger, is faultless where as earlier trials especially on action on limiters (rpm limit especially) would cause lots of harmonics in cam belt and poor signal pattern on cam.
  • 1 year later...
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
