5 minutes ago, whatsisname said:
Yokohama A050, I think they're M compound.
there's your problem lol... put some normal street tyres on the back and strap the car down a bit tighter using the traction bar on the dyno, might see an instant 10~15kW or more!
As it squats and moves forward into the front roller the rear will squat down.
  • Like 1
Cheers. Sounds like a good plan.
Might even give a hub dyno a go at some stage.
4 minutes ago, whatsisname said:
I think easy, Oli's car put down 615kW on a Mainline hub dyno at Mick's Motorsports.
Also runs a GTX3584RS
  • Like 1
Nice! Which turbine housing, 1.01 or 1.21?
Time to locate a local Mainline hub dyno :8_laughing:
4 hours ago, Dose Pipe Sutututu said:
I think just the 1.01 rear, is that right @WantGTR?
I just realised, I've discussed that car and turbo combo' with the owner. R32 GT-R + GTX3584RS 1.01 with 784hp (585kW) at the hubs and a maiden pass of 10.8 @ 140mph at 1600+kg. It is a very impressive set of numbers.
It has changed again
What da f**k is going on here?
The rs is a good turbo.
[mention=11136]Lithium[/mention] scrap your findings. Get a gtx42. Dont be a poof. Relax about dyno sheets. Lol
I concur. The RS is not RS (rat shit).
GTX4202R for the win... power and response [emoji1787]
Dyno sheets are where it's at! Lol
  • 4 months later...
I keep getting asked to update this list with old and new turbos, so I've added some ones "based off request" and also added some current or future units I have some data on.
The G30-770 I have not seen a compressor map for so just made an educated guess as to where it will sit:
  • Like 2
1 minute ago, Dose Pipe Sutututu said:
If you're really bored, compressor inducer/exducer size would be porno
flamin mongrel.
But you're right, I probably should have thought of that at the start
  • Haha 1
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
