Hoping to get recommendations and feedback on where people have got their cars tuned. Also feedback on how much it cost would be great.
Tried to look up previous threads, JEM and Jez DVS seem to be common, but those were fairly old threads.
I have a Nissan R34 GTT 1998 Manual, apexi power-fc, hypergear tubro located in Hornsby NSW.
Originally tuned by Trojan in ACT (previous owner), 265kw at wheels, but is running a little rich. Thinking of just getting a full re-tune instead of a fix up.
https://www.sau.com.au/forums/topic/474994-where-to-get-car-tuned/
I wouldn't get a retune to "fix" it running rich. Blow $1200 for no reason to be honest.
Also it may be tuned rich for a reason, generally with thise high flow turbos, the rear housings are small (because they're OEM) and you often have heaps of exhaust back pressure as you can Only get so much air out versus in due to the upgraded compressor wheels.
Now if you were to have a ruler flat instagrammable AFR reading you might find your car will knock or have sky high EGTs due to the low timing. So to combat this, tuners or mechanics turned tuners dump in heaps of fuel to combat knock.
Anyhow if you feel like getting it "re-tuned" I suggest you reset the PowerFC so they at least have to copy and paste another tune on and touch it up.
  • Like 1
1 hour ago, jorgo90 said:
Not so worried about the running rich part in terms of wasted money etc... The only reason why it bothers me is it spits out smoke and gets oil burn/marks on the rear bumper.
Any other solutions or ideas appreciated.
does your car run a cat?
Well in Australia its simple ...compliant catalytic converter legally required so people wanting to lose the cat usually compromise by
1. putting in a free flowing although not necessarily compliant cat or
2. gutting the cat (so hard to tell from the outside)
3. installing a "test pipe" which may or may not resemble a cat.
Or they just lose it altogether...easy to spot by looking under the car.
I would be more interested to know why it is making only 265kw. What model Hypergear have you got and what injectors,  intercooler, exhaust etc?
Generally Hypergear high flows (back then, no experience with his newer high flows) made around the 250-270kW on a roller dyno.
Tao's test rig often read a bit higher as it was always dynoed on a hub dyno.
Hi Guys,
The engine was rebuilt just before I bought it in late 2016, about 10,000KMS ago (Total bill was 15K, i believe that included a new turbo at the time, engine mounts, new suspension and full dyno etc) - previous owner was a stickler for doing things right, and yes I saw the receipts and spoke to the guys that did it.
The car has Hypergear G3 highflow turbo, spitfire coilpacks, SARD 650cc injectors. Z32 AFM, Walbro 255 Fuel Pump. Exhaust brand is unknown and unknown if it is turbo back or cat back, or gutted cat back etc.
The easiest way is to get under the car and check and see re: cats.
Yes, without a cat you know about it. If people following you get headaches in the hills, you have no cat. It is possible to have a really rich tune and have rear bar discoloration etc with a cat, so ideally you'd be checking both the tune and the state of your exhuast.
G3, relatively old design compared to his more recent & modern turbos.
That result is pretty decent!
Jack up your car, unbolt your car, have a look if it's hollowed out or not!
And if you're really keen on getting a re-tune and burning cash take it to Mark @ MRC Dyno in Castle Hill. He would be my pick if I had to choose a tuner. I've seen his timing maps/tunes and compared to others they're much better.
  • 5 years later...
I'd love to do a fix up but a tuner I went to says he doesn't do that, and it's easier just to do it from scratch because if they fix one parameter it could negatively impact another. I was trying to avoid spending $1k+, is this common with tuners?
Yes, here's a scenario.
Say your original tune by Tuner A has been done, with the wrong injector data, wrong sensor scaling, base timing not synced properly. Tuner B then hops on, fixes up the cock ups and now realises the fuel table & timing tables are pretty much invalid.
Easier for them to copy and paste a known working tune from a similar car they've done in the past with similar mods, then tune/calibrate accordingly
  • Like 1
    • Which are almost all nonsense. Ignore. Obviously enough, if it is not a porous block, then any such thing is a waste of time. External block surface? Would be a waste of time, if the block was actually porous. It would need to go on the inside, which is inaccessible, and even if the block was open deck so that that area was acessible, it would be unlikely to work. But seeing as this is all nonsense, stop worrying about it.   If the coolant is coming from the side of the block it is 10:1 odds that it is either a welch plug, or it is coming from the head gasket. Maybe from one of the coolant lines feeding the turbo, or even the heater. Liquids that leak from up high can travel sideways along casting surfaces or pipes, etc on the engine before finding a spot from which to drop.
    • Yeah rust is sadly also a bit of an issue on my car. Doubt there is many cars out there that actually have no rust in those aeas. The strut towers look fine but some of the surounding metal sheets show a bit of brown cancer peeking out from in between. I hope I can make do with external remedies and won't have to rip open the whole front end anytime soon. It looks somewhat minor compared to some shit I have seen online. I have worked on a few cars but I expect the RB26 to be my first 'engine out' job at some point.
    • Welcome Jan, It's very likely that you are in over your head. You'll just have to learn to swim hard and fast! These old rust buckets have more ways to bankrupt us than almost any other car. But hopefully there's nothing wrong that ruins the whole show! We can help a fair bit. There's plenty here who've been fixing these things for >25 years. cheers
    • Hi all. First off, thanks for reading my post. So end of last season I put the car away knowing I was leaking at least two fluids. One of them being rear turbo's oil. I went to my car recently that is waiting in a garage to take a peek with my boroscope to try and see if I can narrow down the souce of oil before taking it out of storage. What I found is not so great I think. The rear turbo is (probably) leaking from the oil drain. The hose and it's clamps are probably the original ones, so most likely just worn out or loose. However I spotted a line of rust going straight down from the turbo oil feed, as if water leaked out of there at some point. Also explains the red liquid that was dripping from my front subframe, which I initially thought was power steering. I can even see coolant drops hanging off the side of the oil pan as well. After a quick hit on the web I found a select few discussions about porous engine blocks. My question is if the pics of the turbo oil feed and the left hand side of the block (imgur link below) looks like it could be exactly that to you. Maybe someone in the community has seen it before and knows what it looks like. If it actually is a porously leaking block, has anyone attempted at fixing it with simple methods like putting a sealer in the cooling system and using something like jb weld on the block surface, or will it just leak in 2 weeks again? I could not find any detailed info or pictures on this topic. If I need a new engine, tell me softly. https://imgur.com/a/knVvmZ8
    • Hey all. I'm 23 and from Germany, September last year I bought a mildly modded 1995 GTR Vspec. Looks great and was fun so far, but I already have a list of issues of various severity that I need to take care of, potentially growing longer the closer I look. I just hope I'm not in over my head, I really want to keep the car and work towards it becoming great. I hope y'all will help me out in getting there, I am positive I will need help sooner rather than later to figure out how to proceed. greetings, some pics of the car I posted to imgur. https://imgur.com/a/StKkabz
