It has come to my attention that the R34 skyline GT is not very good around corners like i had initially thought
my car came with coil overs but they are maxed out on height. (is that bad for the car?). if i take a fast sharp turn the car starts to skip and sway around.
Also, when i press the brake, it feels like it steers to one side.
How can i improve the handling for the R34 GT?
thanks,
https://www.sau.com.au/forums/topic/475001-horrible-handling-on-r34/
It shouldn't be bad, therefore something is wrong.  Therefore the path to improvement involves fixing the wrong.  Super stiff (Jap brand in particular) coilovers are frequently a bad choice, being just harsh, bouncy and nasty.  Fixing may involve binning them and replacing with something more appropriate, such as a suitable offering from MCA.  But I would strongly suggest you take it to a good suspension workshop and get a survey of what is there, what is good and what is bad, because we can tell you 1000 things and not all of them are going to apply to what you have right now.
Same with the brakes.
  • Like 1
Yeah, you actually don't want too harshly sprung suspension, over corrugations in the road, the car can be unsettled at speed.
Slamming a car too will mess with the suspension geometry and is pretty common if all other suspension arms are factory. Would echo GTSboy's recommendation of getting an expert to look at it and point out what needs fixing.
If it steers to one side, it could also be an alignment issue
Hello Ryan,
Maxed out as in lowered to the limits?
Can you check if the dampening has also been adjusted to suit?
Coilovers usually work well within a range but when they are set to extreme settings for daily duties they tend to fail.
The short travel stroke can result in over agitation of fluids (decreased dampening, ie springy) and components to physically bottom out on bumpstops.
Also the car's roll centres will be really out if you lower too much.
Disadvantages may outweigh benefits.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
