It has come to my attention that the R34 skyline GT is not very good around corners like i had initially thought
my car came with coil overs but they are maxed out on height. (is that bad for the car?). if i take a fast sharp turn the car starts to skip and sway around.
Also, when i press the brake, it feels like it steers to one side.
How can i improve the handling for the R34 GT?
thanks,
https://www.sau.com.au/forums/topic/475001-horrible-handling-on-r34/
It shouldn't be bad, therefore something is wrong.  Therefore the path to improvement involves fixing the wrong.  Super stiff (Jap brand in particular) coilovers are frequently a bad choice, being just harsh, bouncy and nasty.  Fixing may involve binning them and replacing with something more appropriate, such as a suitable offering from MCA.  But I would strongly suggest you take it to a good suspension workshop and get a survey of what is there, what is good and what is bad, because we can tell you 1000 things and not all of them are going to apply to what you have right now.
Same with the brakes.
  • Like 1
Yeah, you actually don't want too harshly sprung suspension, over corrugations in the road, the car can be unsettled at speed.
Slamming a car too will mess with the suspension geometry and is pretty common if all other suspension arms are factory. Would echo GTSboy's recommendation of getting an expert to look at it and point out what needs fixing.
If it steers to one side, it could also be an alignment issue
Hello Ryan,
Maxed out as in lowered to the limits?
Can you check if the dampening has also been adjusted to suit?
Coilovers usually work well within a range but when they are set to extreme settings for daily duties they tend to fail.
The short travel stroke can result in over agitation of fluids (decreased dampening, ie springy) and components to physically bottom out on bumpstops.
Also the car's roll centres will be really out if you lower too much.
Disadvantages may outweigh benefits.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
