Well sorted track car in excellent condition, add fuel and go.
Car is a standard 99 model.
Imported by Tim Hendy in 2007 and used as a tarmac rally car.
Purchased by Sam Markov approx 2014, rebuild as a track car and used at Challenge Bathurst 2016.
Purchased from Sam early 2016 and used for local events, Victorian sprint series 2017, and Challenge Bathurst Nov 2017.
Fresh 2.8L built by Matt Simms Performance - done dyno time only.
  • Spool Billet Crank
  • Spool Pro Drag I beam rods
  • Custom SPS pistons
  • 10:1 compression.
  • Nitto oil pump
  • Bearings calico coated etc
  • N1 block
  • N1 water pump
  • Tomei type B valve springs
  • SM Motorsport custom grind cams
  • 1000cc injectors
  • Royal Purple engine oil
Suspension & Brakes.
  • HKS coilovers
  • Cusco sway bars
  • Adjustable suspension arms all round
  • SM Motorsport front hub bearing upgrades
  • 380mm 8-pot front and 345mm rear 4-pot Ceika brakes
Other bits and pieces.
  • Z-Tune Front guards
  • Topstage Carbon Fibre Front Lip
  • SM Motorsport custom full splitter
  • APR Performance carbon Rear Wing
  • Original front under tray and rear spoiler also with the car
  • 6-Point Cams approved cage. Receipt as per image.
  • Sparco Pro 2000 seat (or Sparco Pro-Adv GRP Tech at additional charge)
  • 6-point harness
  • Motec M84 ECU
  • Motec ADL dash
  • In dash 4wd controller
  • Tilton 7.25'' twin plate clutch
  • Healthy 6-speed Getrag
  • CroMo flywheel
  • Upgraded radiator
  • 100mm intercooler
  • Setrab 40 row oil cooler
  • Power Steering cooler
  • SM Motorsport custom built pedal box
  • Hand control bias adjuster
  • Momo Leather quick release steering wheel
  • 4.1 diffs
  • KAKIMOTO Racing exhaust
  • Project MU wheel nuts
Wheels & Tyres
  • 4 x RAYS Gram Light 18x10
  • 3-sets used Michelin 265x45x18 Porsche Cup slicks
  • 1-set used Kuhmo 265x45x18 soft semi’s
  • Also 4 x RAYS TE37SL 18x10 available - $3000 for the set, they do not come with the car.
I have called Dept of Infrastructure and they have advised that the car can be registered as was imported under the RAWS scheme and complianced but plate never fitted. You will need to contact a RAWS of your choice to have the process finished if you want to register it.
If interested please CALL ME O457 677 243
Located in Albury, NSW.
$92,000
  • 1 year later...
  • 6 months later...
12 hours ago, Hardwork said:
Can you confirm if it is and message me on zero 424 490 18 seven. I reply much quicker by text. Cheers.
Seb
Just call the number - O457 677 243
I am 100% sure he still has the car and it's for sale.
