For sale: Nissan Skyline R34 GTT Sedan 318 rwkw, silver, in Victoria
Key points:
  • Last of the original R chassis with the venerable RB25DET, in the final & best Neo guise
  • Lots of work done: tyres, suspension, steering, drivetrain, mechanical diff, cooling, turbo, servicing, preventative maintenance etc. etc.
  • Beautiful RB bark at 20 psi and the sweet smell of ethanol
  • A registered car with 4 doors, child seat mounting points, big boot, sleeper look for no unnecessary attention
  • No accident history, always garaged under my ownership, regularly serviced
Recent updates:
  • New price
  • New photos
  • New steering rack
  • No RWC selling as is
  • Inspections welcome
Price $14,800
Please PM here or call/email via the full ad: http://bit.ly/4doorad – Photos: http://bit.ly/4doorpics
xCNjIPHOSSHiwj35THtdL35z1m2NsolUazA1EpYa
zAuhocL_6jgoPNvRUTPh2Hv-e6siaDn7QcKk2aFP
n6-2eX8KNijZx5ZY9v1Z8-EDCJKj0CS6Trm6Fw9f
Note: This is a replacement thread for the previous one: https://www.sau.com.au/forums/topic/471783-fs-well-balanced-r34-gtt-sedan-for-street-and-track-vic/?do=findComment&comment=7885711
very nice...GLWS...if you were in Perth I would be taking a look.
Do you have a dyno run on 98? It does dual fuel I assume?
Thanks mate!
On previous tune and fuel system it made 275rwkw on PULP. Current setup is single fuel only as it's not a daily – I can chuck in a couple of 20L jerry cans as part of the sale if you're keen :)
How has this not sold yet? It's genuinely astounding!
If I was ready to trade in the current daily, this would be top of the list!
All the best with the sale mate, hope it goes to a good home soon
  • Like 1
Because people prefer their opinion of looks over functionality and performance.
  • Like 1
  • 4 weeks later...
11 minutes ago, admS15 said:
Congrats on the sale mate, so what's next on the the car agenda?
Thanks mate!
That was the most painful sale I've ever done, there is almost no market for these things, especially at this mod level.
I think I'll take a little while next to recuperate :)
  • Like 1
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
