Team,
I have some Tein suspension that has always been in my car and after my question on replacing bushes I was also looking at the Cusco sway bars.
Problem is I do not know my spring rate in the current coilovers.  They are bound to be stiff though as it is a rough ride.
Do I look to upgrade the sway bars with cusco items which are very stiff front and rear?  Do I use the standard links or is there something else you recommend?  Do I swap the coilovers out for some Tein Flex Z's with adjustable dampers and spring rates on those are Front 7kg  Rear 6kg.
If I do that how do I match the sway bars to those?
This is a street car 98% of the time.
Or do I go Whiteline which comes with a complete kit (links and all) and then adjust with the suspension shop to suit my current teins?
Thanks again.
Edited by Stixbnr32
https://www.sau.com.au/forums/topic/475019-sway-bar-links-and-spring-rates/
And if you have to you can always work out the rate using the method in the stickied thread above.  It's easier on coilover springs than typical OEM springs.
GTRs also usually do NOT have rates like 7F 6R.  They are usually very soft in the rear compared to the front (compared to the RWD Skylines).  This because heavy, understeery blob.
There are 2 schools of thought with this stuff too.  Heavy springs and lighter ARBs, or lighter springs and heavy ARBs.  Both give you the same overall roll stiffness, but of course one is much more compliant (with reduced left-right independence) and the other is tuned for faster bumps and has better left-right independence.  I recently softened the rear bar from a 24mm adjustable to a 22mm adjustable and made the car much better to drive.  Made both ends feel better, which was unexpected.  I tend to think that really stiff ARBs are more trouble than they are worth.
What is recommended for a Street GTR spring rate wise?  Keep in mind might do the odd track day.
Cool it goes into the shop next week to raise up 20mm (big sump to close to the ground) so I will get them to check spring rates for me and come back to you guys.  No point going ultra stiff if its not required.
Edited by Stixbnr32
Hello Brent,
Don't be afraid to upgrade if you feel the need to.
Swaybars are a safe enough swap for a commuter as you only really notice them when they flex (potholes rather than speed humps).
From what I have heard swaybar bushings are another important factor in ride compliance.
I think standard links will suffice. I believe adjustable endlinks are generally used to remedy misaligned suspension geometry due to excessive lowering and to balance corners via preloading. Might be excessive in your circumstance. Although you may want to consider refreshing the rubbers on the endlinks to keep everything tight.
I do like the fact that Whiteline provide a whole kit.
Keep us updated with the results!
Yeah the whiteline kit looks really good and after talking to some folks I might have to buy it.  We will see how the car drives after I raise it the 20mm as its far to low now im older (had the car for 7 years) haha.
Just checking with a friend when he is back from holiday might be able to get a discount.
They don't look bulletproof no. However after breaking oem links, then mounts, i used the adjustable ones- advantage is more, to position them for correct movement rather than twisting the link/mount. Haven't had any issue with them.
I would look at the cars handling characteristics and go from there, understeer/oversteer.
There's alot more to it than just putting bigger bars on.
I wrecked my old 33 by going to big with the bars and to stiff with the springs.
I sacrificed traction front and rear in the end.
From my experience, which was from doing it wrong, what you really need to do is find the spring rate for the cars use, whether it's track, street or a mix of things, get your dampers to suit.
Then after an alignment and tyre playing with tyre pressure see how the car handles, you may be happy, you may not, maybe you need to only replace 1 bar, maybe bigger, maybe smaller.
I am by no means an expert, as stated, I f**ked my 33 handling by missmatching parts due to ignorance.
SAU NSW had a tech night at Heasams (spelling?) not long ago, I went to one years ago at a different joint, from that night I learnt that I was doing it wrong (after spending thousands to make my car handle "worse"), they talked alot about springs/damper/bars/alignment/tyre pressure and how you need to look at it as a whole and not the individual part.
Rock and roll
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
