Hi guys, I'm wanting to add some carbon fiber canards to the front of my R33 GTR (original series 3 bumper) but don't want to drill holes in case I want to remove them in the future. Do you know if there are any industrial strength double-sided tape or the like to keep them in place but won't ruin the paint on my bumper if I decide to remove them in the future?
I don't like the 4-piece AutoSelect/ACE style ones which extend onto the front indicators and are looking to get the simple two-piece ones like shown below but because they're not specifically made for the R33 GTR bumper there's some gaps in the centre so will need to be apply more tape to fill gaps.
Any experiences here guys? I don't just don't want to drill holes into my bumper.
Image result for r33 carbon fiber canards
Related image
Related image
Edited by Robocop2310
https://www.sau.com.au/forums/topic/475033-installing-canards-without-drilling/
Sikaflex, or try your luck with some 3m stuff. Any really strong option is going to eventually damage the paint.
Paint is easy to fix, holes mm not so much - considered pricing up a second bar for this? The bar alone shouldn't be too unreasonable?
Thanks for all your replies. I might look at some options as I don’t want to damage my front bar ahd certainly don’t want to get another one as it’s a genuine series 3 GTR front bar.
Thanks again guys.
7 hours ago, UWISSH! said:
All r33 gtr front bars are the same. It’s only the lips that determine what series it is so just get a spare bar for when u feel like changing
Thanks mate. I thought the series 3 front indicator slots are a little different too but I stand to be corrected.
Anyway I decided in the end to not install the canards as using double sided tape was tacky and glue would be the same as screwing them on plus it looked a bit showy. I’m a fan of the clean look anyway.
On 9/30/2018 at 8:44 AM, UWISSH! said:
The actual indicator plastic on the passenger side has an open slot from memory now but that’s it
Cheers mate. Much appreciated.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
