Last night I started having a problem with my car, a 1992 R32 GTR. The car has HKS GT2530s and standard camshafts and comes on to hard boost around 4000rpm.
When the car is coming onto hard boost at 4000rpm the car just "dies" and looses all power and the power fc warning light in the dash comes on and stays on solid. I know if it flashes in 3 increments at 0.5 second intervals it means detonation, and if the intervals are longer its the injectors maxing out, but this is just staying on solid and the injectors are nowhere near maximum (Sard 700cc) and the knock level is 1. The car is also still getting fuel as it comes flooding out the back of the exhaust (occasionally in a pretty orange/white burnt form), but I just cant figure it out. Spark plugs seem ok and are gapped at 0.8mm. It also has Z32 AFM's which were cleaned about 2 months ago. The car is running 1.2kg/cm2 boost.
When the car dies it sort of just splutters but doesnt sound like its misfiring.
Any ideas on what the problem could be?
Thanks.
Yeah the rev limiter is set to 8250rpm (factory rev limit). I forgot to mention this setup has been working faultlessly for the past few months, nothing was changed on the PowerFC, it just all of a sudden started doing this.
Thanks for your suggestion though, appreciated :)
Could be Ill add that to my list of things to check, thanks. Any other ideas?
When it "dies" it doesnt stall it just stops revving, tested it this morning and this time it sounded like its hit a rev limiter sort of thing. My main concern is that the light hooked up to the power fc to blink if theres a problem is coming on and staying on until a few seconds after i back off.
First test, put the Commander into Monitor mode and watch the display closely at 4,000rpm. It may pay to have the passenger do it or point the video camera at it then play it back for analysis later.
Second test, fuel filter and/or fuel pump, check the fuel pressure at the rail.
My best guesses :(
  • 4 weeks later...
Just as an update, the CAS was loose, tightened that up and the car hasnt played up since. It has also fixed the hunting for idle problem I was having too.
sorry to bring up a old thread and ask a dumb question, but what is the "CAS"
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
