Last night I started having a problem with my car, a 1992 R32 GTR. The car has HKS GT2530s and standard camshafts and comes on to hard boost around 4000rpm.
When the car is coming onto hard boost at 4000rpm the car just "dies" and looses all power and the power fc warning light in the dash comes on and stays on solid. I know if it flashes in 3 increments at 0.5 second intervals it means detonation, and if the intervals are longer its the injectors maxing out, but this is just staying on solid and the injectors are nowhere near maximum (Sard 700cc) and the knock level is 1. The car is also still getting fuel as it comes flooding out the back of the exhaust (occasionally in a pretty orange/white burnt form), but I just cant figure it out. Spark plugs seem ok and are gapped at 0.8mm. It also has Z32 AFM's which were cleaned about 2 months ago. The car is running 1.2kg/cm2 boost.
When the car dies it sort of just splutters but doesnt sound like its misfiring.
Any ideas on what the problem could be?
Thanks.
Yeah the rev limiter is set to 8250rpm (factory rev limit). I forgot to mention this setup has been working faultlessly for the past few months, nothing was changed on the PowerFC, it just all of a sudden started doing this.
Thanks for your suggestion though, appreciated :)
Could be Ill add that to my list of things to check, thanks. Any other ideas?
When it "dies" it doesnt stall it just stops revving, tested it this morning and this time it sounded like its hit a rev limiter sort of thing. My main concern is that the light hooked up to the power fc to blink if theres a problem is coming on and staying on until a few seconds after i back off.
First test, put the Commander into Monitor mode and watch the display closely at 4,000rpm. It may pay to have the passenger do it or point the video camera at it then play it back for analysis later.
Second test, fuel filter and/or fuel pump, check the fuel pressure at the rail.
My best guesses :(
  • 4 weeks later...
Just as an update, the CAS was loose, tightened that up and the car hasnt played up since. It has also fixed the hunting for idle problem I was having too.
sorry to bring up a old thread and ask a dumb question, but what is the "CAS"
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
