Hi guys - Apologies if this is the wrong section
So recently had my R34 GTT tuned running an RB25DET neo. Tuner said that at around 5000rpm he can hear a noise when listening in through the knock sensor. The ECU is picking it up as knock sometimes but it isn't actually knock. He said its almost a metal-on-metal sounding noise, and it starts at 5000rpm and dissapears at 5.5 every single time. Cannot hear it from outside the car, only when listening in through the knock sensor.
I'm hoping for some help in narrowing down what it is. My dyno numbers are perfectly fine (will upload the sheet later tonight), power curve is stable etc. He believes it is something harmonic related as it is only at that RPM range. Have done runs with VCT disabled and it still makes it so that is not the culprit. He has suggested to me that it may be the intake cam gear although he's very rarely heard of them failing.
My issue is they are a stupidly expensive part to replace for a "potential" fix. His other suggestions have been potential scoring on the cam lobes. Have you guys got any input on this? So noise starts every single run at basically dead on 5000rpm, stops at 5500. Almost a really fast " drdrdrdrdrdr" noise (best way i can describe it). One other thought by him was potentially a lifter.
Unsure if this matters, but the car's running an S2 RB25DET neo, nistune ECU, 14psi boost, front mount, full exhaust, cold air intake. Car is also only 104,000kms. Car still drives perfectly fine and would have had no idea anything was making noise had he not told me.
Any advice would be greatly appreciated!
https://www.sau.com.au/forums/topic/475073-rb25det-neo-strange-noise/
Could very easily be the VCT.  On/off makes no difference to it being broken enough to make a noise!
If it truly is a harmonic sort of thing, then the biggest culprit would be timing belt/tensioner.  Some aftermarket cam belts slap around like crazy.  Or the tensioner could be unhappy.
Would not suggest cam lobe scoring as likely to cause anything at all, let alone a noise that comes and goes at a certain rpm.
On the topic of belts/idlers/pulleys
When was the last time the timing belt/major service was done? could well be bearing noise from either the water pump OR the idler OR the tensioner pulley
The cambelt was done at around 90thousand. He's told me he doesn't think it's cambelt related as its a more metal-on-metal type noise. I did suggest the cambelt to him but he didn't seem to think so. Although a tensioner/idler would make sense for a metal noise. I'm unsure if the belt is a genuine Nissan one i'l have to check.
Is there a way to diagnose if one of the idlers is the culprit, or the VCT gears? He seemed pretty adamant that my VCT was not the culprit either. I was planning on taking the front cover off and having a look. But you can only hear this noise when listening in through the sensor, making it immensely difficult to pinpoint and diagnose.
I don't want to go replacing components just for there to be a "chance" of it fixing. Any ideas of how to narrow this down? Or check if any of your suggestions could be the cause?
Ive had some recent experience with similar, the vct was rattling metal on metal noise on cold start.
Had a metal scraping noise too, this was simply the backing plate rubbing on the cam gear, not much holding it back, probably happens from someone leaning over the motor with a fat gut lol.
 And finally another rub noise was the timing belt too tight, GL with it..
Were your noises audible through just listening from outside the motor? As my biggest issue is that I cant actually hear anything... May take the cover off though and see if it is rubbing or something of the sort.
Yeah were quite loud noises at idle speed  my tuner says the vct gears are becoming a more common issue.  Id be shining a bright light around the backing plate, see if theres rubbing and also slacken the belt a touch if its a bit tight.
Edited by AngryRB
4 hours ago, GTSBoy said:
What grade of oil are you using?  If there is scope to go a little heavier it might be worth a try.  The noise might be a gudgeon or something similar talking that might quieten with thicker oil.
I believe i'm currently running Fully synthetic 10w40. Just did an oil change less than 500kms ago. Are you meaning the gudgeon pin that holds the piston to the rod?
@AngryRB i'l give that a whirl this weekend and hopefully I have some luck!
So i’ve taken the CAS off and inspected it. Couldn’t see anything funny but there was some scoring on the part the CAS bolts into (see photos).
Cambelt didn’t seem overtight and was replaced at a Nissan dealer so assume that’s not the culprit.
Does this scoring look normal? Also couldn’t see any rubbing marks on the cover.
Thanks heaps for the help so far
Replace the gasket/spacer in your upper cam belt cover, ie hole where the CAS passes through.  Stop contact/grinding on the CAS mount with proper clearance.
Will do! Any idea where I can source one of these from? Or do I just use normal washers?
As a side note, i've been lead to believe that the previous owner lied to me and that the cambelt has not been done. Inspection of the belt is showing marks that shouldn't be there. So either the cambelt hasn't been changed, or it has but the tension has been set incorrectly. Am going to do the cambelt again with a new idler, tensioner, waterpump and seals. Hopefully this remedies the issue...
Thanks heaps for the advice so far! Will update afterwards :).
Try with Kudos Motorsport, or Nissan.
Cam belt is not a massively difficult job to replace, so if in doubt throw another one on.
FYI timing belts deteriorate pretty quickly, not structurally but visually. Do a couple 1000km on a new belt and it looks very old very quick.
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
