23 minutes ago, ERO54N said:
Hello Raefalot,
Mine flash when I lock or unlock using remote.
How come?
Mine are not flashing but no idea why and I wasn’t sure if they were meant to or not.
what model is yours and do you have any alarm or aftermarket central locking installed that might be doing the flashing or is it stock?
It's how your remote has been programmed. Are you using a stock remote or aftermarket?
Most remotes will change how the lights/sounds are triggered by programming the remote.
Try holding the lock and unlock buttons together for 3 seconds to trigger lights off and on again during unlocking/locking.
Let us know how you go.
Cheers.
Cheers.
Hey thanks,
its stock remote, no alarm or anything aftermarket.
i think I did try that but nothing changed.
ill try it again, just waiting for the car to get back from the workshop.
cheers
Edited by Raefalot
3 hours ago, Raefalot said:
Hey thanks,
cheers
No worries mate. Try a few combos with the buttons like holding lock/unlock together for 5 seconds then just lock and then separately just unlock for 5 seconds and then try unlocking to see if it's turned back on.
Otherwise, try resetting the remote. Besides that call Nissan and get them check it out.
Good luck.
On 10/8/2018 at 6:33 PM, Raefalot said:
Hmm, tried all the combos and resetting the remote using the instructions in the workshop manual but still no flas haha.
any other ideas?
Hey mate, tried this - unplug your battery and leave it off for 30 minutes or so to reset the car. May act as a hard reboot and the central locking resets back to stock settings. Probably won't do anything but nothing to lose.
Good luck.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
