From the other side of the world
Nightprowler
 Share
So live in New York, after banging my head against a keyboard trying to get any info out of the US forums I found you guys and gals. Even as a lurker I found you guys to be incredibly helpful. Also you seen to be much more willing to push the limits more.
Current car is a 1990 R32 GTR 128 Km
mod list includes:
  • 94 RB26TT
  • 94 Trans
  • Stock turbos w/steel internals
  • HKS intercooler and  piping
  • HKS BOV
  • HKS intake
  • Aftermaket Cam pullys
  • Manuel Boost Controller
  • N1 Oil Pump
  • N1 Water Pump
  • Exedy single clutch
  • Nismo Downpipe
  • ISR stainless steel test pipe
  • Nismo Catback (I think its for a R33 it has the carbon fiber tip)
Planned/considered mods:
  • Nistune(already on its way)
  • Make the damn Nismo exhaust loud
  • Cams
  • EBC?
  • Injectors
  • Coil pack
  • Turbos
  • R34 Trans
  • The Moon
Would love some advice on any of the above mods or any things you think i should do first, especially the EBC and coil packs. Currently looking to get 4-450 whp with the current set up with an overall goal for now is to get to somewhere in the range of 550-600 whp maybe 700 if I'm feeling frisky. Only real issue with the car so far is that it keep over boosting to the point that I can go 3/4 throttle without it spiking to 20 psi (feels amazing/scares the hell out of me).  Look forward to hearing what you guys have to say and can't wait to build this machine.
  • Like 1
Gidday!
How about some pics of your car?
New or better coils should be high on the list as should some kind of electronic boost control.
Consider a single turbo conversion:
http://www.goodezilla.com/rb26dett-skyline-gtr-single-turbo-vs-twin-turbo
Cams can wait - a good tuner will get the best out of your current set up with the adjustable cam gears.
Six speed gearbox would be nice but probably new turbo set up a better use for your money. Then injectors to suit.
Happy spending - I mean modifying!
Coil packs will probably be the next upgrade along with an ignition harness. Car had issue just after I got where it developed a stutter at low RPM(under 4k) and at less than half throttle. After freaking out that it might be the timing we ended changing out the spark plugs first and discovering that the plug for cylinder two was shot and likely causing a misfire. Issue went away following the plug change but I have a nasty sneaking suspicion that it'll come back and that the real culprit is the coil packs. Other issues include a leak from where the intake manifold meets the throttle bodies due to shoddy  paper gaskets which probably didn't help matters. New gaskets are in route.
As for an EBC any suggestion on brand? I have a MAC EBC in my Spec.B and have had no issues with it. Also if one of you could kindly point me to an install write up that would be amazing. Give that to the best of my knowledge the R32 didnt come with a EBC Im not terrible certain how to wire it up.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
