Some of the buttons work, some don't. I can control the temperature, but can't seem to change the fan speed or use the off button.
AMB doesn't work and neither does defrost.
Should I replace the unit or does this sound like a wiring/sensor issue?
https://www.sau.com.au/forums/topic/475093-r32-ac-controller-acting-up/
If you're ok with soldering you could try pulling it apart and looking for dry joints to re-solder since that issue has been noticed on other stuff (eg AFMs and the digital clock). Probably easier to just get another tho.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
