Just test drove a Q60 and loved it. But there is a deal breaker... My head hits the roof. All models come with a sunroof too.
Has anyone modified their seat to go lower?
I know it can be done on the V36 coupe. But the dealer wouldn't let me remove parts of the Q60 seat to have a look :)
I'm about 6"2
https://www.sau.com.au/forums/topic/475098-infiniti-q60-headroom/
Take the plastic cover off that's around the base.
At the front of the seat there is a cylinder with a bolt and 3 washers. Take off 1 or 2 washers.
Drops a few cm.
I did this year's ago so this just my memory.
I'm sure there is a step by step in this forum.
  • 7 months later...
Anyone driving a Q60 that has done this mod or is willing to see if it can be done to their car?
i'm about to buy one in a few weeks and i might have to get a Q50 just because of the head room :(
I feel it's such a weird thing to not buy a car over another car.
Paul... I will ask this question on Facebook Q50/60 that has 16K plus members ..
 I was told on the FB forum, you can do the same thing you did on the Q60 as you did on the G35/G37 to reduce the seat ? height
Edited by wizlb
  • Thanks 1
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
