Ive just recently checked vaccum lines AGAIN, cleaned my afm, aac valve on my rb25det neo thinking that will solve my low rev hunting issue but still hasn't changed my problem. I followed the tutorial on how to clean the aac value, followed mostly everything on the tutorial but when it came to the adjustment on the idle i realised the the tps on the neo's are different? From here i became puzzled so if anyone has any information on this topic im all ears.
My neo's completely standard only has a tap on it.
Any help will be good. Thanks.
Edited by Dbro
https://www.sau.com.au/forums/topic/475108-idle-issue/
Hey mate, not too sure what you mean by low revving issue? As you saying you cannot rev high or are you saying at low revs something is acting up for example it's idling rough?
Before you do anything, check turbo gasket, exhaust piping, hoses connecting air cleaner and blowoff valve if you have one.
Then let us know further.
https://www.sau.com.au/forums/topic/475108-idle-issue/#findComment-7888375
When the car is at a stand still the revs are abnormally low, when you put your foot on the accelerator and then take it off suddenly the revs drop really low, at some points almost causing it to cut out. Even when its just turned on and hasnt warmed up the revs are low. Thanks for your help!
https://www.sau.com.au/forums/topic/475108-idle-issue/#findComment-7888391
I think the turbo gasket is broken or come off and check air filter clamps and hosing.
Also check check and clean out Throttle body plate and air intake valve. Dirt deposit sometimes builds up in these areas over time. Just remove and clean with some grease remover and soft cloth. Or you can buy an air can and spray.
https://www.sau.com.au/forums/topic/475108-idle-issue/#findComment-7888458
  • 3 weeks later...
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
