17 minutes ago, mizorex said:
I feel ya man, im in a similar boat. Best bet is to chip away at it over time.buy second hand parts and start youtubing a shittonne.
Yes, and also make new videos to post to YouTube.
Omg thanks for the reply everyone !! Glad to know there’s a great community going on here!
Just a quick update for everyone about the car that looks great but doesn’t run properly !
Turns out the head gasket needs replacement.. and the mechanic also discovered the A/T light keeps flashing and he did the diagnose to check the errors and it turns out my transmission needs a new solenoid as it’s locked in limp mode..
Slowly finding out more and more terror!
If only money was growing in my backyard tree.
But thanks everyone big lesson learnt!
To be honest, the body is the hardest and most expensive to fix. The mechanical stuff you can replace/repair (would need maintenance and repair eventually anyway). I would start saving for tools and trying to do work on it (if you have the space/garage/shed), paying for others to fix it will get expensive.
This could be a long project for you, and you'll end up with an awesome car in the end.
  • 3 months later...
On 1/23/2019 at 7:07 PM, 34Red said:
UPDATED : I ended up selling the car as it was just getting worst every time I drove it, got rid of it and decided to get a 350Z and probably best decision I’ve made sticking with Nissan.
That was not outcome I expected, hope you enjoy the tree fiddy. You had a great platform for a project car, I'd be interested to see where or whom it has gone to and what their plans are for it.
Sounds like my R34 sedan experience - although my seller was a lot more honest about its history and condition. I still lost interest and flogged it after having it sitting around for a couple of years and losing about 3-4k on various repairs and upgrades
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
