Hey everyone. I just got a manual conversion done on my 1998 r34 gtt and now it is running funny. It revs very slow and goes slower then my na r34 now. It is still running the auto ecu. Im thinking that might be the problem? Or maybe the coils? Please anyone that has had this kind of problem let me know.
Ps. Sorry if this is in the wrong part of the forums
Auto ECU will not be the problem.  The only difference between auto and manual ECUs (apart from slight differences in mapping) are that the auto ECU also contains the TCU.  Oh, and the idle ignition timing is 20° in autos, not 15° like in manuals.
There could be the usual million explanations.  From coils, to dirty AFM or faulty wiring.  Perhaps you need to do a diagnostic on the ECU and looks for codes.
  • Thanks 1
Ok thanks mate i will give the diagnostic tool ago and see what it finds when i get home. The car seemed to run fine before it was converted. If the car was running fine before could it still be the coils?
Also the car has no aftermarket mods except a hks catback
Edited by TaylorS
The logical source of problems would be wiring that was f**ked up during the conversion.  The driver's side engine bay loom that services the plugs on the transmission is an example of a place that you need to make changes.
Coils much less likely to die except by pure coincidence.  AFM wiring, oxy sensor, knock sensors are all more likely to be abused during work in the engine bay.
  • Thanks 1
Ok thanks for the tip mate. It wasn't me who did the conversion, i got it done from a shop so i really hope its not the wiring because i wouldn't know what to do then because the shop isnt sure why its like that either.
I will charge the coils anyway and will put some spitfires in.
I should also add that at random points in the higher rpm it seems to kick in and then drops back out again.
Sorry for all the questions and stuff
3 minutes ago, TaylorS said:
Thanks for the tips mate, i will check that out too
All good mate.
Also as some have suggested plug in a cable and run some diagnostics if possible.
Could also be the exhaust too check piping.
  • Thanks 1
4 hours ago, TaylorS said:
Ok definitely will try that tomorrow. Do you think it could be a boost leak causing all this?
Yes definitely a possibility but jack the car up and check exhaust piping ang turbo gasket first followed by hoses and blow off valve leakage.
  • Thanks 1
Couple of times I've had the circlip on the turbo actuator arm fall off and the actuator disconnect. First time it was on a CA18DET and ran absolutely gutless. It's also happened on my RB25DE (with turbo conversion) but wasn't as bad cos the compression is higher so just felt like it was running non-turbo again.
  • Thanks 1
Thank you for that, i will check that out as well. It could be anything at thid point haha. It does run guttless so it could be that
Update: hey everyone i was playing around with the car and i think i have narrowed the problem down to a turbo issue. it seems like i am getting no boost. the boost gauge reads all the way up the top of the gauge at max and i can hear the turbo spalling  but it feels like im getting none of it?
does anyone know what could be wrong from that kind of an issue? is the bov broken?
thank you
hey everyone i have a few updates.
To begin with i totally forgot to mention that the A/T light has been since the conversion. is this normal?
i also checked for error codes and it came up with error 34 which is knock sensors. does this have to do with the A/T light?
thank you in advance
knock sensors have nothing to do with the AT light.
If you arent making any boost but your turbo is still making all the woosh sounds them im going to say you have a massive air leak or there is a rag in your intercooler piping.
  • Thanks 1
Ok thank you mate, i didnt think the knock sensors have anything to do with the AT light.
Yes your right the turbo is still making all of its noises but it doesnt want to boost.  I will have to check out the intercooler next.
Also can the knock sensors casue the car to get no boost? Maybe trigger a safe mode or something?
Whilst you’re get it check your AFM and wiring/tubing to your air intake and intercooler.
  • Thanks 1
    • That's awesome. Fully serviced/full log book history for one of those cars is super rare from what I know. With JDM's like Skyline's, Supras, are quite hard to find one with full log book history. S15's seem to be somewhat of an exception, at least the spec s australian delivered models.
    • Hey all, It's been a bit since I have been able to update.  I pulled the fuel pump, first off it was a "universal" pump and the strainer was very clogged, and it was folded over on itself.  I replaced the fuel pump and all is well....  No more stalling.
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
