Most likely one of the thousands of posts about idle problems with an RB engine. So, my r34 has been running like a dream. I've owned it for about 4 months, and never had a single problem. Put in a boost controller myself about 2 months ago, never had a problem. In the last week, my car has decided to drop to 500RPM when warm, and at a complete stop, and in the last day, it's done the same thing, but the idle was very rough and a bit up and down. Here's a video of my car idling, ignore the engine as for some reason on camera it comes out to be extremely loud, but IRL is a lot quieter for some reason. I just wanted you to focus on the exhaust pattern, as that's what I'm referring to when I say rough idle. This morning when I cold started it, it did the rough idle thing, dropped to 500RPM, and went rough, rough rough and then stalled for the first time ever, started it up 2 seconds later and was all good, started fine no worries. I took of the cam cover to check the timing belt, but it looks like it's in very good condition. No tears or anything. Here's the video: R34 idle Problems
I'm in need of some feedback if possible, just some recommendations on what I should look to fix, maybe if someone has experience the same problem I'm having. Cheers heaps guys!
https://www.sau.com.au/forums/topic/475134-r34-gtt-idle-problem/
It's misfiring.  Could be recent change in fuel composition (end of winter mix, start of summer mix) depending on where you are.  Could be dirty plug(s).  Could be dirty AFM.
The video showed it idling at ~1000rpm.  I assume it was still warming up.  If it's settling to 500 rpm (where it should be aiming for 650rpm) then that could be because of the miss, or it could be because the IACV is clogged enough to stop it controlling.  The IACV incorporates a wax pellet cold start valve that gives you your cold engine high revs but it will close as the coolant warms and if the IACV can't control with the stepper motor then you can lose idle revs.  I had to clean mine recently because of this.  Was dropping to (nice) idle of 400rpm.  Not satisfactory for driving though, as it can and will stall.
Cheers heaps GTS boy, i did actually experience misfiring about a week or 2, took out 1 of the coils looked fine (was late and had to get somewhere), so I just put it all back together after checking 1. I was driving to 80km/hr and was in 2nd at about 5k RPM, car made what I can describe as a 2step firing noise, then kept going. That happened twice but under the same circumstances, never had a problem since. I checked the consult port for errors, and got code 55 which is 'no malfunction', so that's all clear. Just bought some throttle body cleaner, will get to all the air control valves when I get home. Really appreciate the help, and will keep this thread updated just in case anyone else has the same problem
Cheers heaps GTS boy, i did actually experience misfiring about a week or 2, took out 1 of the coils looked fine (was late and had to get somewhere), so I just put it all back together after checking 1. I was driving to 80km/hr and was in 2nd at about 5k RPM, car made what I can describe as a 2step firing noise, then kept going. That happened twice but under the same circumstances, never had a problem since. I checked the consult port for errors, and got code 55 which is 'no malfunction', so that's all clear. Just bought some throttle body cleaner, will get to all the air control valves when I get home. Really appreciate the help, and will keep this thread updated just in case anyone else has the same problem.
Also, just driving my car now, I'm experiencing really strong stutter when I'm upshifting, feels like turbo lag but turbo is hitting boost fine on the stock gauge. I'd explain it as stuttering but it's more of a hesitation, I'm shifting at about 5k, and it takes a good second to actually tourqe up again, and keep powering, hence why it feels like turbo lag, but yeah hitting high PSI fine
Here's an update: so I've changed the spark plugs, used electric dialect on all coil packs and cleaned all of them. It must be just a faulty coil pack. I've also cleaned the AFM sensor with some contact cleaner. Literally no change in performance. This must narrow it down to be the coils. I'm looking to get some spitfire coil packs, might as well go all out as I'll be adding heavy mods soon.
  • 1 year later...
I know that it’s been two years, but did you ever find out the problem, I am having the same in my 1999 R34 RB25DE NEO, have replaced the coilpacks and harness and spark plugs, have checked my AFM, and no change have put some injector cleaner in and there was a slight improvement but it’s still idling low and rough
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
