Hey blokes, I've looked on a dosen forums, and people are the sphincter of the universes about this. Im looking into getting a set of rims for my R33, and I want the rims to be as flush with my guards as possible. I have no idea about offsets, so im gonna need a dummy guide, cause I'm an A class dummy when it comes to rims.
https://www.sau.com.au/forums/topic/475138-help-new-rim-offset/
Go 19" if you can and choose:
9x10.5 +15 or + 12.
Other sizes will work too. But size above in 18/19 is best IMO.
Will fill guards nicely.
Depends if he has a gtr or gtst.
If it’s a gtst then what you suggest doesn’t work
Also 19s r homo.
18s with a correctly sized tyre is the way to go
Also 19s r homo.
Agreed that 19” is more for looks to fill guards.
Yeah I’m assuming it’s a GTR otherwise won’t work on GTS.
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
