Hey Guys, for anyone interested I'm organising a run of UAS pivoting upper control arms. Am aware of alternatives on the market but these being (easily) on car adjustable is a big part of why I want the UAS design on my own car.
I have fourteen buyers on the Z32 forum and eleven spots available if anyone here is keen. $395/pair and I'm taking deposits $197.50 if anybody wants to split payments. I'm mainly active at the AUS300 forum but send me a PM via SAU if you're interested or have any questions and I'll get an email alert so should get back to you pretty quick.
Have copied some more details below
Some info below
Why A Pivoting Front Arm?
  • By design, the front camber arm is required to pivot as it travels through its arc as shown in the video below
  • Without this pivoting centre, the centre of the arm is subjected to torsional load that leads to breakage, worn bearings, and failed adjusters.
About the Pivoting Arms on Offer
  • Improves suspension and steering as it allows unrestricted movement. They are harder wearing than the factory version and other after market control arms.
  • Tig welded, zinc plated, alloy spacers with NSK Bearings
  • Camber Adjustable
  • Suits R32, Z32
  • "Street" Spec to correct negative camber on lowered cars. Total length can be adjusted roughly 170-190mn. Stock length is 178mm.
Version 3 Camber Arms
These will be Version 3 camber arms, which have been improved to address some of the issues experienced with the version 1 arms released in 2009. Key points include pivoting mechanism moved to the center, larger threads, and larger CNC machined body. They are on-car adjustable.
Freight is not included with your order and will be billed with the balance.
Freight to AUS: $20/pair
All prices in $AUD.
On 10/15/2018 at 10:19 AM, R.3.2.G.T.R said:
In
Haven’t heard back since I PM’d you -I’ve got nine spots left so please let me know if you’re still interested
Just an update; I’ve been told the sample will be sent to me tomorrow. Once I’ve done a test for and confirmed everything is 100% the production run will be on.
  • 3 weeks later...
  • 3 weeks later...
PM is always welcome and comes with a convenient email alert at my end :)
I don’t have any shipping info yet so assuming not sent. I’m in pretty regular contact with the factory so as soon as I have something concrete I’ll post in here.
Hey guys, I have been advised that these will leave the factory by end of this week. Not sure how we’ll go with Christmas delivery but either way shouldn’t be long now
Parts are in the air -ETA to me including holiday delays etc is Jan 2. I’ll be in touch re balance and freight once I have the parts.
In the meantime this is quite literally your last chance to order at $395/pair.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
