Ok. So I've made another post about my car not idling properly, being generally rough and having hesitation when accelerating. Now, if you've seen my other post, you'll know that I've changed my spark plugs, put some spitfire coils in, cleaned the AFM and everything was running fine still. The car still ran and was drivable. Now, only since I took off the TPS and tried cleaning it, the car is no longer drivable. No freaking clue why my tps would do this, but now when I press the accelerator, the car almost dies. It's responding to the tps changing resistance, but it's as though it's being flooded with air or something. But when I press it, the idle doesn't go back up, it stays at that certain rpm range. The video of what I'm trying to explain is at the top. Really need some help as I need my car to at least be drivable for tomorrow. Cheers.
https://www.sau.com.au/forums/topic/475152-r34-new-acceleration-idle-problem/
So why is it when the accelerator is pushed, it sounds like the engine is 80 years old and about to die? And would that also explain why the TCS and Slip light is on? Or is that a problem on it's own?
Can't tell you exactly why the engine plays up when you blip the throttle. Probably depends on which direction you have it maladjusted.  Suffice to say, that the ECU needs to know where "closed" is and needs to know where "not closed" is (ie, everywhere else!) and uses that knowledge to decide whether to be on the idle maps or running on the main maps.  Needless to say, it won't run well on the wrong map.
You need to put the ECU into diagnostic mode and see what/if fault codes you have in there.  The ECU will report on the TCS DTCs that affect it.
Also, which TPS did you f**k with?  The engine's one?  Or the one on the TCS throttle?
Haha okay so I was a dipshit and when I put it back on, I did it so when you press the accelerator, the little thing that would push the tps would not move at all, so the engine had no Signal coming from the tps at all lol. I took of the tps in line with the actual throttle body tensioner and all that. Got the car running nice now, idle is back to the old problem of being rough and still hesitates, but the car runs. Back to square one. I think it might be either afm or the ignition coil harness
  • 4 weeks later...
**Update**
So it ended up being the fuel pump, I'm sure these symptoms would be the same with a faulty fuel pump, but turns out my problem was just because the pump hose that sits in the tank had ripped open due to how it was mounted to the bracket, so it was loosing a shit tonne of pressure. All fixed now and mounted correctly. I'll attach the before and after pics
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
