Hey Guys,
So I've blown a headgasket in my rb25 r32 gtst. I've had a few problems with it with the MAF and some idle issues, but now the headgasket has died.
I've been tossing up between just fixing the rb25 head gasket or leaving it for a little bit and building a rb25/30 on the side. If anyone has done it would you say its worth it and what power are you pushing and how much did it cost?
What do I do??
Thanks
https://www.sau.com.au/forums/topic/475157-stay-with-rb25-or-go-rb2530-r32/
15 minutes ago, Sh*t R32 said:
What do you mean? Like if I were to go RB25/30?
He means that the RB30 block is taller than the RB25 block - around 30 - 35mm from memory. You need to lower the engine (by cutting or getting smaller engine mounts, allow it to sit closer to the bonnet (and probably remove the strut brace if you have one), or a combination of the 2.
We've done it with a track car, and it is fantastic. The extra ltorque low down is a real bonus. You haven't mentioned what's been done to your RB25, but you would probably need a tuneable ECU to get the most out of an RB25/30. Cost - how long is a piece of string. It will depend on what else you do at the same tiem - rebuild the RB30 bottom end, provide for better oil control, rebuild the head, modify the head to enable VCT, upgrade the ECU, upgrade the turbo, upgrade the fuel system. Pick a number that you want to spend & triple it.
  • Like 1
Yep go RB30 and, depending on your ambition, go as cheaply as possible. Just clean up the block and do rings and bearings get a decent turbo, intercooler, exhaust and ecu. new fuel pump and injectors. Keep the stock manifolds, throttle body fpr and cams. You will love the way it drives.
Unless you are made of money and want bling in which case the sky is the limit.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
