Hey Guys,
So I've blown a headgasket in my rb25 r32 gtst. I've had a few problems with it with the MAF and some idle issues, but now the headgasket has died.
I've been tossing up between just fixing the rb25 head gasket or leaving it for a little bit and building a rb25/30 on the side. If anyone has done it would you say its worth it and what power are you pushing and how much did it cost?
What do I do??
Thanks
https://www.sau.com.au/forums/topic/475157-stay-with-rb25-or-go-rb2530-r32/
15 minutes ago, Sh*t R32 said:
What do you mean? Like if I were to go RB25/30?
He means that the RB30 block is taller than the RB25 block - around 30 - 35mm from memory. You need to lower the engine (by cutting or getting smaller engine mounts, allow it to sit closer to the bonnet (and probably remove the strut brace if you have one), or a combination of the 2.
We've done it with a track car, and it is fantastic. The extra ltorque low down is a real bonus. You haven't mentioned what's been done to your RB25, but you would probably need a tuneable ECU to get the most out of an RB25/30. Cost - how long is a piece of string. It will depend on what else you do at the same tiem - rebuild the RB30 bottom end, provide for better oil control, rebuild the head, modify the head to enable VCT, upgrade the ECU, upgrade the turbo, upgrade the fuel system. Pick a number that you want to spend & triple it.
  • Like 1
Yep go RB30 and, depending on your ambition, go as cheaply as possible. Just clean up the block and do rings and bearings get a decent turbo, intercooler, exhaust and ecu. new fuel pump and injectors. Keep the stock manifolds, throttle body fpr and cams. You will love the way it drives.
Unless you are made of money and want bling in which case the sky is the limit.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
