Hey everyone, I just thought I should ask everyone’s opinions on my problem. I plan on buying a Datsun c211 as a project. It will be my first project car and I don’t know what engines will fit without any major changes. Such as if any rb engines would fit?
thanks in advance to anyone that can help and I look forward to reading your advice.
https://www.sau.com.au/forums/topic/475180-datsun-engine/
21 hours ago, GTSBoy said:
All of that can be fixed too.  There's no point in building one of these as a resto-original project.  No-one cares about an old slow Skyline.  An old fast Skyline is cool.
Depends what OP is trying to do I guess.. around the world I'd say more people would be into the old slow (but sounds cool af with triple carbs) Skyline than an RB swapped basically S13 underneath..
  • Like 1
https://www.sau.com.au/forums/topic/475180-datsun-engine/#findComment-7888128
I like triples, but superchargers sound better.  I like superchargers, but turbos are massively better at making power.
In a world where NA engines are 6+ liters......~2.5L NA 6s are just missing something vital.  Power.  And torque.  This is fixed with boost.
The only old Skyline I would leave unmolested is a genuine GTR.  All others are fit only for scrap or speed projects.  Let's face it - the interior of any 1970s Jap car is no nice place to be, even if you drop cubic $$ on retrimming.  They are just nasty, poorly laid out ergonomic nightmares with twinky instruments and noodle thin control stalks.  You need something to take your mind off of all that when driving them.  Hell.....my R32 is a nasty place to be inside of, and it's not as if it's worn out and stuffed.  It is near factory perfect.  It's a hell of a step up from an R31, which in turn was a step up from the 70s.
Don't get me wrong - I'd have a 70's Skyline as a project (if I had the time/space/energy) in a heartbeat.  I don't hate them.  But I am very realistic about what they're good for.
https://www.sau.com.au/forums/topic/475180-datsun-engine/#findComment-7888135
It's definitely different strokes for different folks. Power is not what it is all about when owning these classics.
Decide what you want to get out of the car before buying engines. Remember going RB will be sump, fuel, diff ,gerbox mods. Plus you'll have to open up the tunnel to fit a larger gearbox. Then you will have engineering headaches if done legally.
You could put some triples on the engine, better camshaft, exhaust and have a nice car. If you want to go a little further you can do some piston swaps to bring up compression and/or port the head. Again, just depends on what you want to do.
https://www.sau.com.au/forums/topic/475180-datsun-engine/#findComment-7888819
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
