My tuner just did some before and after pulls with HKS Vcam and shared on his Facebook.  I would like to share that here for those thinking about Vcam.
His car is still running on stock R32 turbos with steel turbine wheels.  The pulls were done on E60 ethanol mix.
https://www.facebook.com/houston.zauto/posts/1368728369930762
Edited by TXSquirrel
  • Like 1
  • Thanks 1
https://www.sau.com.au/forums/topic/475195-hks-vcam-before-and-after-on-r32/
I extracted more info out of him, really hope he doesn't mind me posting this.  RPM across the top and load on the left.
Question for you folks about how camshaft degree translates into cam gear degree.  His HKS exhaust camshaft has a centerline of 110, and he gained across all RPM range by retarding his exhaust cam gear by 2 degrees.  My Tomei has a centerline of 115, to get the same effect how should I adjust my cam gear?
Yeah the difference from 3000 to 5000 rpm is astonishing.  My tuner made his pulls on stock R32 turbos, so with any decent aftermarket turbos the improvement should be more pronounced.  He has actually pushed hard on those stock turbos and intends to blow them up as he has a pair of 2530 waiting to go on, but they are surprisingly tough.
When you say on vs off, do you mean activated vs not activated? or optimal vs sitting at base conditions?
Its still a slightly misleading comparison as your off isn't going to be as optimized as a normal dumb cam.
Still, I wants it.
  • 3 months later...
On ‎10‎/‎26‎/‎2018 at 1:26 PM, r32-25t said:
44D1F837-CFAD-4BE9-9F56-7CBFBF112A88.thumb.jpeg.6da56bba0d835cbf55f7c97858eab354.jpegthat is a difference with vcam turned on and off my car, this is a very conservative 98 tune before we swapped to e85
But look at all that top end power it lost! That 1.5kW is a huge price to pay... :10_wink: :4_joy:
  • Haha 2
Camshaft and gear degrees are identical.  2° is 2°.
That may not answer your question.  And the lesson learned by retarding the HKS cam by 2° may not be applicable to your cam.  Those sorts of changes really come down to what effect the change has on the overlap of the in and ex lobes.  As your centrelines are so different, then it is quite likely that the overall profiles of your cams are quite different and you may end up with a different result.  You might need more retard, or possibly less, or possibly gain from a little advance.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
