Hello! I need to change front differential in my R32 gtr, do i have to take the engine out or is it easier to just drop down the front end?
And is there anything else i should know/think about?
I bought an engine, then my gearbox broke. I checked the front diff ratio and it was 4.5 while rear diff was 4.1 (R32). And ofc I forgot to change it before a the new engine came into place..
Any idea what the front differential might be?
Thanks
https://www.sau.com.au/forums/topic/475202-r32-gtr-front-diff/
I don't know of any Nissan with that low a front diff ratio. The R34 GTR front (and rear) is 3.545. R32 and R33 GTRs are 4.1
The GTS4 is 4.375
I believe changing the front diff is best done engine out but someone may know better.
The GTS4 is 4.375
I know, thats the wierd part..
Forgot to tell you guys that there is a Getrag 233 on the car! (r34 gtr). Maybe that has something to do with ratio on front diff? Because i checked the ratio by spinning the prop shaft (correct name?) the front one.
Whats the price on a r32 front diff without sump? Anyone ships to sweden? :)
6 hours ago, BK said:
No need to remove engine at all for front diff change. By all means it's easier to setup backlash on crown wheel and pinion while engine is out and / or sump off.
Okey, thanks. Ill probably try to change diff without getting the engine out at first. Or just drive rwd.
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
