Hello my name is Nick I'm from Pa USA traded my evo9 to get a r32 gtr. It's been pretty rough so far but my current issue is with spark.
Ok guys I'm having an issue with ignition. Car is 90 r32 gtr. Seems like the CAS is not firing the injectors or coilpacks. I get signal to the coils and injectors but with the CAS removed and the ignition on when I spin the CAS im not getting any spark from the plugs or clicks from injectors. I have all new harness for coils a new ignitor box and a friend loaned me his CAS but still she wont fire. Could it be the ECU? Also not getting any signal from the harness to the CAS but i don't have my voltmeter to confirm exactly. I am getting power to the injector and coilpack harnesses. Just wont fire. Anyone have advice. Not much on this problem anywhere. Service manual is confusing and I have searched this forum but can't find a good way to test the ECU to see if it's the problem. Thanks for any input.
https://www.sau.com.au/forums/topic/475208-new-r32-gtr-owner-with-spark-issue/
Welcome but you should post in the RB Skylines section not here.
