Hi guys, I’m going to start doing a new post-grad course for work so will have less time to drive my cars so will have to give them a good service/clean then store away in the garage for a while. I have never owned a car cover but thought I’d take this opportunity to get nice custom GTR ones like the below photos but it seems only R35 GTR ones are available?
Does anyone know where to order them from, prices and do they last?
Cheers!
images?q=tbn:ANd9GcR7lNV8R4gcRbzJ8L3Yb-M
images?q=tbn:ANd9GcQGG3ig6N_QHx3-wJQBQpu
Edited by Robocop2310
5 hours ago, Leroy Peterson said:
People do custom covers... But you gotta measure it yourself. Havent seen any 33GTR specific covers.
Do you have any reputable custom cover makers in mind?
Cheers
Cheers
Thats where i got mine from, decent quality
https://www.coverworld.com.au/car-covers/custom-car-cover.html
i dont always use it because detailers tell people not to use covers at all... for indoor storage with no wind i got recommended covercraft
https://www.covercraft-pacificshop.com/
Thanks mate.
Why don’t detailers suggeset covers?
Because they claim it leaves scratches, no matter the quality or material. Mainly because dirt and debris often cling to the inside and scratches paint when removing/applying. My paint is far from perfect so I don't really notice it or put on the cover too often anyway.
Sheets could do, if you can bothered to sow and cut them to shape, otherwise: edges would touch the ground and get dirty, need to remove/apply multiple sheets, get blown off with wind.
Thanks mate.
Interesting concept. I guess if the cover itself is dirty or has dirt and rock particles stuck to it, this could in turn attach the car.
Appreciate tre info.
4 hours ago, GTSBoy said:
For indoor storage some old sheets are all that's required.  As if spending money on custom car covers.  Set fire to a pile of $20 notes.
Fair enough. Thanks mate.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
