I had my apexi N1 coils (99 spec) repaired last winter by ohlins specialist. Cant remember exactly what he did, but all the shocks had leaked and now they seem to do ok.
Ride is a bit hard for a road car though, iirc the springs were around 10/9kg or something like that. Shocks are now at mid stiffness (15 or 16 klicks, goes to 32). Been wondering if I could/should get a bit softer set of springs and which ones to get. Atleast rhdjapan seems to sell lots of generic springs that should fit
On 10/23/2018 at 10:54 PM, niZmO_Man said:
Yeah Fortune is equiv to MCA imo
You can also get KYB/Koni/Bilstein + springs (probably easier to get it from Japan).
Are these spring rates comfortable enough for in town or highway roads as well without breaking my tailbone on road imperfections.
Contact the guy, tell them you want comfortable street suspension. If they can't help you, look elsewhere.
You don't want high spring rates unless they're valved really well, you want something a low lower like 6/4 or get standard/Nismo suspension.
Or just get BC coilovers
Link to Nismo S-Tune suspension: https://www.rhdjapan.com/nismo-s-tune-suspension-system-kit-r32.html
This is what I got for bc racing coils. What do they mean by “extreme low”? The height in my car now is pretty damn low with what I believe are the apexi coils
I recently installed a set of 8/6kg BC Golds in my 33 and I'm happy with them. Good quality for the price, when set up right they handle really nicely as well as retain a decent level of ride quality, albeit pretty firm its not crashy. I daily drive 120km each day on bumpy secondary roads. MCA would have been nice but would have cost around 2x as much to get here in NZ.
51 minutes ago, SeanR32GtSt said:
As it currently sits. I measured 23 inches from fender to ground.
f**king inches!
Measure from the guard lip directly above the centre of the wheel down to the centre of the hub cap.  Wants to be about 345mm.  What you have looks to be too low (for good handling, and for clearing speed humps, drains, etc).
20 minutes ago, GTSBoy said:
f**king inches!
Lol sorry mate. Here in the states we tend to be all “anti conformity “ with the rest of the world lol. But this current height does wel with our speed bumps. I don’t have to go sideways or nothing. Just go at it at no more than 10km. I’ll take another measuring pic when I get home tonight from school.
How low does your car sit?
As low as I could get it without the guards resting on the front wheels when you turn them. A little lower than in that pic as it has settled since then. I had to modify the front inner guards, tuck the wiring loom up higher, roll all 4 guards and fit extra bump stops to the rear to stop the wheels hitting the body under full bump.
That looks good. Sits about as low as mine. My BBS wheels are 17” so it gives the more low illusion I think.
Nice, yours is looking good too. Yeah its easier to get the car lower to the ground on 17"s, Im running 235/40r18 so its quite a large tyre.
Getting the heights is actually pretty fussy. When I got my BC's the body length was adjusted pretty close to right to allow the maximum amount of suspension travel without the tyre contacting body anywhere. So you should be able to just install them as is and they will be decent. But if you want to go lower that's when you have to make some careful adjustments, then drive the car to let the springs settle a little and adjust from there. Took me ages to get all 4 corners even and at the height I wanted. Then I had to add spacers on the rear shocks to limit the shock travel while still retaining captive springs.
Sounds fussy. I got a mate that lives bout 10km from me with access to a lift. Our game plan is to match the current coils with the new ones. Set the dampers to middle point of soft and hard. Lower the car off the lift and check the height. Then drive for a minute to check tyre rub. If not equivalent to what the car ride height was before we will lower it some more and repeat the same process.
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
