I had my apexi N1 coils (99 spec) repaired last winter by ohlins specialist. Cant remember exactly what he did, but all the shocks had leaked and now they seem to do ok.
Ride is a bit hard for a road car though, iirc the springs were around 10/9kg or something like that. Shocks are now at mid stiffness (15 or 16 klicks, goes to 32). Been wondering if I could/should get a bit softer set of springs and which ones to get. Atleast rhdjapan seems to sell lots of generic springs that should fit
On 10/23/2018 at 10:54 PM, niZmO_Man said:
Yeah Fortune is equiv to MCA imo
You can also get KYB/Koni/Bilstein + springs (probably easier to get it from Japan).
Are these spring rates comfortable enough for in town or highway roads as well without breaking my tailbone on road imperfections.
Contact the guy, tell them you want comfortable street suspension. If they can't help you, look elsewhere.
You don't want high spring rates unless they're valved really well, you want something a low lower like 6/4 or get standard/Nismo suspension.
Or just get BC coilovers
Link to Nismo S-Tune suspension: https://www.rhdjapan.com/nismo-s-tune-suspension-system-kit-r32.html
This is what I got for bc racing coils. What do they mean by “extreme low”? The height in my car now is pretty damn low with what I believe are the apexi coils
I recently installed a set of 8/6kg BC Golds in my 33 and I'm happy with them. Good quality for the price, when set up right they handle really nicely as well as retain a decent level of ride quality, albeit pretty firm its not crashy. I daily drive 120km each day on bumpy secondary roads. MCA would have been nice but would have cost around 2x as much to get here in NZ.
51 minutes ago, SeanR32GtSt said:
As it currently sits. I measured 23 inches from fender to ground.
f**king inches!
Measure from the guard lip directly above the centre of the wheel down to the centre of the hub cap.  Wants to be about 345mm.  What you have looks to be too low (for good handling, and for clearing speed humps, drains, etc).
20 minutes ago, GTSBoy said:
f**king inches!
Lol sorry mate. Here in the states we tend to be all “anti conformity “ with the rest of the world lol. But this current height does wel with our speed bumps. I don’t have to go sideways or nothing. Just go at it at no more than 10km. I’ll take another measuring pic when I get home tonight from school.
How low does your car sit?
As low as I could get it without the guards resting on the front wheels when you turn them. A little lower than in that pic as it has settled since then. I had to modify the front inner guards, tuck the wiring loom up higher, roll all 4 guards and fit extra bump stops to the rear to stop the wheels hitting the body under full bump.
That looks good. Sits about as low as mine. My BBS wheels are 17” so it gives the more low illusion I think.
Nice, yours is looking good too. Yeah its easier to get the car lower to the ground on 17"s, Im running 235/40r18 so its quite a large tyre.
Getting the heights is actually pretty fussy. When I got my BC's the body length was adjusted pretty close to right to allow the maximum amount of suspension travel without the tyre contacting body anywhere. So you should be able to just install them as is and they will be decent. But if you want to go lower that's when you have to make some careful adjustments, then drive the car to let the springs settle a little and adjust from there. Took me ages to get all 4 corners even and at the height I wanted. Then I had to add spacers on the rear shocks to limit the shock travel while still retaining captive springs.
Sounds fussy. I got a mate that lives bout 10km from me with access to a lift. Our game plan is to match the current coils with the new ones. Set the dampers to middle point of soft and hard. Lower the car off the lift and check the height. Then drive for a minute to check tyre rub. If not equivalent to what the car ride height was before we will lower it some more and repeat the same process.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
