Hey everyone, as some of you know the 'old' style nismo carbon garnish doesnt age the greatest and looked quite cheap after a while. After seeing the new nismo logo, i knew i had to have a set. I've taken a couple of pics for comparisons...even though the differences are subtle, the new logo sits up a tad higher and seems to be of a much better quality. This is on an r33 gtst20181024_161236.jpg20181024_160727.jpg
Thanks for the interesting comparison mate.
Call me nuts, but I actually find the older CF pillar more tougher with the lighter less glossy finish and looks more tougher in my opinion. The logo itself is exactly the same except for the letter O.
Cheers
  • Like 1
Cheers
Your right with the older ones looking tougher. I do prefer how the older one is actually a thicker sticker. I felt ripped off when i saw how thin the new one was lol and hopefully the 'o' is less susceptible to fading compared to the older nismo logo, which was my main reason for replacing them. Now If only they re-released the 'nismo' gtr wing end caps with the new logo [emoji57]
4 minutes ago, Ty1 said:
Your right with the older ones looking tougher. I do prefer how the older one is actually a thicker sticker. I felt ripped off when i saw how thin the new one was lol and hopefully the 'o' is less susceptible to fading compared to the older nismo logo, which was my main reason for replacing them. Now If only they re-released the 'nismo' gtr wing end caps with the new logo emoji57.png
Yep totally ageeed mate...but, the new one looks  much newer and clean! I have the older garnish on my R33 GTR and the bottom ends are starting to break a little but seeing it’s an older car I don’t mind it looking a little brittle. ?
you can certainly get the Nismo and caps directly from Nissan or good online stores but it only shows on one side as Nismo mirrored obviously won’t look right and having it read from left to right on the left side is a bit funny.
Hi guys, ant chance somebody could tell me how the original garnish is attached to the B pillar. Someone has tried to use a master key to break in and busted one of mine off at the top. TIA
I've never had to remove one but to me it looks like they sort of clip in as i was able to slightly move it up and down while applying the garnish
You need to unscrew a few bolts holding it against the side wall trim. There’s also a few plastic clips holding it in place. Removing the door/wall trim is done with unclipping some points with a flathead screwdriver but be gentle as it can break.
Thanks tor the advise.
Yep totally ageeed mate...but, the new one looks  much newer and clean! I have the older garnish on my R33 GTR and the bottom ends are starting to break a little but seeing it’s an older car I don’t mind it looking a little brittle. [emoji106]
The actual nismo stick-on end caps through nissan?? Im talking about the caps with the word 'nismo' printed on them. I know you can still get the ones with gtr printed on them but i havent seen brand new nismo ones for years now [emoji22]
5 hours ago, Ty1 said:
The actual nismo stick-on end caps through nissan?? Im talking about the caps with the word 'nismo' printed on them. I know you can still get the ones with gtr printed on them but i havent seen brand new nismo ones for years now emoji22.png
Hey mate sorry I mistaken the GTR ones for the Nismo ones.
You mean these ones?
https://www.google.com.au/imgres?imgurl=https%3A%2F%2Fi.imgur.com%2Fz3aU8tL.jpg&imgrefurl=https%3A%2F%2Fimgur.com%2Fgallery%2F4M5Yy&docid=yFPgnAWXw7Lv6M&tbnid=F3JSp1gCgtOeBM&vet=1&w=480&h=360&client=safari&ved=2ahUKEwiou7nBs6beAhVigEsFHfPVCqUQMygAegQIABAw
Edited by Robocop2310
  • Like 1
Hey mate, personally I don't think it you should have Nismo end caps unless you're going for the R33 Nismo 400R look with bodykit and similar wheels and the works. I have GTR end caps on and find it looks best but each to his own of course but agree hardly see them around unless it's been self fabricated.
  • Like 1
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
