Yes.  But what you have in your bay does not match the manual.  The line you are holding IS going between the canister and a solenoid, but the solenoid is behind the PS reservoir, which would tend to suggest that it is the boost control solenoid valve, not the purge solenoid valve.  Just follow the lines in the last image I posted and you will see what is supposed to connected to where.  I can't show you a completely useful photo of mine, because it is in an R32 and the canister is different.
  • Thanks 1
Thanks a munch for your help mate. Yes your correct, it was auto but has been manual converted recently. I have been having boost power issues since the conversion, the boost just seems to drop out after 4k rpms and only kicks in around 3k rpms. Sorry to complicate things mate but im trying to find anything that is related and im thinking this might be
47 minutes ago, GTSBoy said:
That's the boost control solenoid.
I have an electric boost controller and may have mistaken it but doesn’t this line hook up to a manual boost controller on some cars?
Edited by Robocop2310
The OEM boost control solenoid is hooked up to vent some of the boost signal from the compressor outlet tapping port on its way to the wastegate actuator.  the instant you put in any other sort of boost controller (manual, EBC, whatever), the original solenoid is no longer used.  The new boost controller then does what the original one used to do.
  • Thanks 2
Ok thanks mate, i dont have a manual boost controller so do you think this is why i am having boost issues?
1 minute ago, GTSBoy said:
It's in the last picture I posted.
I cant tell where there going to in the diagram. It looks like it goes to something on kr near the pipe but i cant see anything like that in my engine bay. Also i have this t piece here, is that normal or are those lines meant to go to the solenoid?
You won't find anyone who can show you a photo of a stock setup, because no-one has a stock setup.
So, if you look at the last diagram, you will see where hoses are supposed to sit, and if you look at the first diagram, and follow the pipes between the solenoid, turbo outlet and turbo inlet, you should be able to work it out, including the T piece.
  • Thanks 1
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
