TaylorS Posted October 27, 2018 Share Posted October 27, 2018 Hey everyone, for the life of me i cant find a diagram for a rb26det neo. I have noticed im missing this vacuum line and i cannot find where it is meant to go. Thank you Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/ Share on other sites More sharing options...
TaylorS Posted October 27, 2018 Author Share Posted October 27, 2018 1 hour ago, TaylorS said: Hey everyone, for the life of me i cant find a diagram for a rb26det neo. I have noticed im missing this vacuum line and i cannot find where it is meant to go. Thank you sorry i meant rb25det neo**** Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889193 Share on other sites More sharing options...
Robocop2310 Posted October 27, 2018 Share Posted October 27, 2018 1 Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889194 Share on other sites More sharing options...
GTSBoy Posted October 27, 2018 Share Posted October 27, 2018 ^ Nope. It's not that line. The only line that is supposed to be in that area runs from the top port of the purge control solenoid at the rear of the coil cover, to the top port of the charcoal canister at the front of the bay. 1 1 Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889195 Share on other sites More sharing options...
GTSBoy Posted October 27, 2018 Share Posted October 27, 2018 1 Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889196 Share on other sites More sharing options...
GTSBoy Posted October 27, 2018 Share Posted October 27, 2018 1 Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889200 Share on other sites More sharing options...
TaylorS Posted October 27, 2018 Author Share Posted October 27, 2018 4 minutes ago, GTSBoy said: Hey thank you for the help guys. This is so weird because there is only a vac line coming off the canister. So my vac lines are wrong then Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889202 Share on other sites More sharing options...
TaylorS Posted October 27, 2018 Author Share Posted October 27, 2018 The vacuum line is going to this? Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889205 Share on other sites More sharing options...
GTSBoy Posted October 27, 2018 Share Posted October 27, 2018 Yes. But what you have in your bay does not match the manual. The line you are holding IS going between the canister and a solenoid, but the solenoid is behind the PS reservoir, which would tend to suggest that it is the boost control solenoid valve, not the purge solenoid valve. Just follow the lines in the last image I posted and you will see what is supposed to connected to where. I can't show you a completely useful photo of mine, because it is in an R32 and the canister is different. 1 Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889206 Share on other sites More sharing options...
TaylorS Posted October 27, 2018 Author Share Posted October 27, 2018 4 minutes ago, GTSBoy said: Yes. But what you have in your bay does not match the manual. The line you are holding IS going between the canister and a solenoid, but the solenoid is behind the PS reservoir, which would tend to suggest that it is the boost control solenoid valve, not the purge solenoid valve. Just follow the lines in the last image I posted and you will see what is supposed to connected to where. I can't show you a completely useful photo of mine, because it is in an R32 and the canister is different. Thanks a munch for your help mate. Yes your correct, it was auto but has been manual converted recently. I have been having boost power issues since the conversion, the boost just seems to drop out after 4k rpms and only kicks in around 3k rpms. Sorry to complicate things mate but im trying to find anything that is related and im thinking this might be Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889207 Share on other sites More sharing options...
TaylorS Posted October 27, 2018 Author Share Posted October 27, 2018 (edited) Ok so i have reconnected the purge solenoid to the caniater. I cant tell from the diagarms where the vacuum lines are meamt to go from this? Edited October 27, 2018 by TaylorS Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889220 Share on other sites More sharing options...
GTSBoy Posted October 27, 2018 Share Posted October 27, 2018 That's the boost control solenoid. Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889225 Share on other sites More sharing options...
TaylorS Posted October 27, 2018 Author Share Posted October 27, 2018 Yes sorry i should of called it by its name. I can see where the vac lines go to from it in the diagarms Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889227 Share on other sites More sharing options...
Robocop2310 Posted October 27, 2018 Share Posted October 27, 2018 (edited) 47 minutes ago, GTSBoy said: That's the boost control solenoid. I have an electric boost controller and may have mistaken it but doesn’t this line hook up to a manual boost controller on some cars? Edited October 27, 2018 by Robocop2310 Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889229 Share on other sites More sharing options...
GTSBoy Posted October 27, 2018 Share Posted October 27, 2018 The OEM boost control solenoid is hooked up to vent some of the boost signal from the compressor outlet tapping port on its way to the wastegate actuator. the instant you put in any other sort of boost controller (manual, EBC, whatever), the original solenoid is no longer used. The new boost controller then does what the original one used to do. 2 Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889241 Share on other sites More sharing options...
TaylorS Posted October 27, 2018 Author Share Posted October 27, 2018 8 hours ago, GTSBoy said: The OEM boost control solenoid is hooked up to vent some of the boost signal from the compressor outlet tapping port on its way to the wastegate actuator. the instant you put in any other sort of boost controller (manual, EBC, whatever), the original solenoid is no longer used. The new boost controller then does what the original one used to do. Ok thanks mate, i dont have a manual boost controller so do you think this is why i am having boost issues? Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889249 Share on other sites More sharing options...
TaylorS Posted October 27, 2018 Author Share Posted October 27, 2018 does anyone have any pictures of their factory boost control solenoid all connected up? i need to know where the vacuum lines go exactly Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889251 Share on other sites More sharing options...
GTSBoy Posted October 27, 2018 Share Posted October 27, 2018 It's in the last picture I posted. Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889254 Share on other sites More sharing options...
TaylorS Posted October 27, 2018 Author Share Posted October 27, 2018 1 minute ago, GTSBoy said: It's in the last picture I posted. I cant tell where there going to in the diagram. It looks like it goes to something on kr near the pipe but i cant see anything like that in my engine bay. Also i have this t piece here, is that normal or are those lines meant to go to the solenoid? Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889256 Share on other sites More sharing options...
GTSBoy Posted October 27, 2018 Share Posted October 27, 2018 You won't find anyone who can show you a photo of a stock setup, because no-one has a stock setup. So, if you look at the last diagram, you will see where hoses are supposed to sit, and if you look at the first diagram, and follow the pipes between the solenoid, turbo outlet and turbo inlet, you should be able to work it out, including the T piece. 1 Link to comment https://www.sau.com.au/forums/topic/475255-r34-gtt-vacuum-line-diagram/#findComment-7889259 Share on other sites More sharing options...
