1 hour ago, TaylorS said:
Fix all the lines rhey are correct now and still having same issue where it wont get boost below 3kish rpm and and wont boost over 4kish rpm.
The part that gets me the most is that the car runs perfect when cold
You might want to buy or borrow a cheap manual boost controller like a Turbosmart one for around $60 and plug it in. My gut feeling says it will solve all your issues as the boost pressure is being regulated whereas who knows where it’s going now? Auto stores like Autobarn and Repco should stock them.
If it doesn’t work, you’ll know it’s not this issue and only spent a small amount of money,
Your call of course.
Link on eBay: TURBOSMART Boost Tee Manual Turbo Boost Controller Black/Blue https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F142976642714
Edited by Robocop2310
5 minutes ago, Robocop2310 said:
You might want to buy or borrow a cheap manual boost controller for around $80 and plug it in. My gut feeling says it will solve all your issues as the boost pressure is being regulated whereas who knows where it’s going now?
ok thank you for your suggestion mate. whats the best kind of boost controller? sorry im new to turbos
5 hours ago, TaylorS said:
Ok thanks mate, i dont have a manual boost controller so do you think this is why i am having boost issues?
My gut says yes. See above message but of course this is just a hunch without seeing your engine bay in person.
For a cheap amount of money I would try.
  • Thanks 1
Get any manual boost controller like the Turbosmart one.
  • Thanks 1
thanks mate, i will try that for sure. to install it do i just take off the 2 vacuum lines off the stock boost controller and then put them on the turbosmart one?
Here you go mate.
  • Thanks 1
3 hours ago, Robocop2310 said:
4 hours ago, GTSBoy said:
Maybe a video showing both the tacho and the boost gauge on a 3rd gear pull will help us?
Hey installed the boost control. I have it almost all the way closed (turned all the way anti clockwise and then one click clockwise) ans still the same issue. Definitely felt a difference though. Heres the video of a 3rd gear pull. As you can see it revs very slow (i had my foot all the way down) ans then when it hits 3k rpm it runs up and then cuts out after 4k rpm
Disconnect the boost tee altogether.  Leave the hoses there, open.  Drive it.  Floor it.  See if the boost comes on and immediately goes straight to overboost (like waaaay too much boost).  If it does, we're starting to learn something.  if it still refuses to boost, then we also learn something - that something else is wrong.
Things that could be wrong here.  Blocked fuel filter, f**ked fuel pump, dirty injectors, maladjusted CAS (timing), blocked cat, crushed exhaust, rag in the intercooler pipe, something wrong with the wastegate/actuator.
Also, I cannot tell from your photo if you have the tee hooked up correctly.  Draw a sketch showing exactly where every connection goes.
  • Thanks 1
Hey mate, good to hear some improvement.
Upon viewing your video, I cannot hear the actuator opening or closing at all although granted low revs.
Also do you have a stock or aftermaeher BOV check for leakage there too.
Be patient and check all your hoses and hosing to and from your air intake and wastegste etc it feels something is wrong around these areas and fasten and tighten everything.
Also like GSTBOY suggested please take better photos of how the boost controller is installed.
  • Thanks 1
Thanks so much guys for your fast replys.
Red is from wastegate to boost tee.
Yellow is from boost tee to t piece.
White is to turbo from t piece
Black is to turbo from t piece
Yeah im not sure if wastegate opens ethier.
I checked the fuel filter, it was very clean. I feel like it is over boosting too. Because when it kicks in at about 3k it kicks on very hard and then stops very abruptly. Also earlier this week my mate had his boost gauge connected to it and at some points it was hitting 15 psi. (Beofre i redid vac lines and installed boost controller)
once i find out if i have the boost controller hooked up properly i will try disconnecting it altogether and see how that goes.
No aftermarket bov. everything is stock expect the catback which is a hks turbo back and wheels.
Hey mate, according to your drawing:
Red is from waste gate to boost tee - CHECK
Yellow is from boost tee to t piece - CHECK
White is to turbo from t piece - ??
Black is to turbo from t piece  - ??
Why two tubes to turbo? Should one go to engine bay (plumb back valve) or an external blow off valve?
The below diagram shows how Turbosmart suggests the manual BC to be installed.
Suggest you also clamp the sides to the BC too as one sold appears to be not fully in?
Image result for how to install manual boost controller on internal wastegate
Yup, as above....do not hook anything up to the "tee piece".  That's going to the stock boost solenoid, which is part of the problem.
Hey guys thanks.
Nothing is hooked up to the boost solenoid. Sorry i dont know what the valves are called that each part of the piece is going too. I will show a picture of where each end of the t piece is going too.
Its abit hard to see black but hope this makes sense.
