Get rid of any connection involving that T piece!  The boost T goes in a single (cut, of course) hose between the boost source and the wastegate actuator.  That other T is leading off into the wilderness, and is causing you to have no idea where the boost signal is being lost.  Just pull the T connections apart and block everything other than your connections to the boost T.
Ok i will get rid if the t piece. Switch one do i have the other end of the boost control go to? The white circle or the black circle? And do i just block the other one off or just leave it with nothing? Sorry for the dumb questions
See my recent setup diagram and follow that plus above and you’ll be right.
Ok so i would just attach the vac line that is in white direct to the boost controlller and then just block off that other line or leave it open?
Thanks mate
Hey mate,
I think this may work. I'll summarise briefly:
- Turbosmart BC piece will have to ends connected; one goes to the Wastegate actuator port and the other to the Turbo's boost port (located along the throttle body). So if you have any other connections left, it ought to be blocked off completely as at the moment it's going back into your stock boost solenoid. Also check all clamps and ensure there is no leakage anywhere...check AFM too and air intake too.
- Once you correctly hook everything up. Turn the car on and led it idle for around 10 minutes for the ECU to recognise the changes - this may do nothing but I've always done this to give the car a chance to accept changes and it's never harmed anything so you may want to give it a shot nothing to lose then take it for a drive and see what happens?
If this doesn't work then there's something more sinister at work here so you.re better off taking it to a mechanic.
Good luck mate.
Image result for r33 gtst turbosmart manual boost controller
  • Thanks 1
Thanks mate, will give this ago. Im probaby thinking it will have to go to a mechanic as well. I was hoping to avoid that because im kinda broke after the manual conversion.
I have checked and cleaned afm before because thats what i tried first. Also changed coils and sparks as well.
Fingerscrossed this works.
Good luck mate. I understand playing around with cars is a bottomless pit.
If the problem is if this doesn’t fix it it may be something that’s damaged so you will have to take it to a shop to avoid further damage.
7 hours ago, Robocop2310 said:
Hey mate,
Good luck mate.
Thanks mate, i will show you want i have done before i test it. I hope the photos arent confusing.
The  2rd and 3rd are of the turbo tee. Waste gate to tee and i couldnt find anyother line down there so that has to be for the turbo that other line near the waste gate? Anyway thats connected to the turbo tee.
I blocked off the sononoid.
I blocked off the tee piece that was going back from the turbo to the intercooler.
Also that line that is coming from the throttle body is already connected to something else (first picture)
Edited by TaylorS
The first 2 are of the turbo tee. Waste gate to tee and i couldnt find anyother line down there so that has to be for the turbo that other line near the waste gate? Anyway thats connected to the turbo tee.
Also that line that is coming from the throttle body is already connected to something else (last picture)20181029_093000.thumb.jpg.044c3d994bf0f1794a8f2e696dc12927.jpg
Hey mate, I cannot make our exactly what’s what from your photos but the one end needs to go to the throttle body for boost pressure as mentioned above so I don’t understand why it’s not hooked up and where else it’s going.
Follow it with your fingers and see where it goes?
  • Thanks 1
2 minutes ago, TaylorS said:
Ps. Irgone my edit the photo order kept charging so i changed where wach photo is.
1st two photos are turbo tee.
Last photo is throttle body
Please confirm exactly where the two tubes on the side of the MBC (manual boost controller) are connected to?
  • Thanks 1
Hahah sorey mate, everytime i reload this page the order of photos keep changing. This is the photo of where the 2 lines are going to off the manual boost controller
Make sure you blocked off everything else these two connectors look good.
Fire her you and let it idle for 10 minuites then take for a drive to test.
Good luck mate!
  • Thanks 1
Good luck mate!
Thanks mate, will give it ago. Should i adjust the manual boost controller or is the setting its on good? (Turned all the way anti clock wise) with one click clock wise)
Hey guys, still no luck :/ looks like i will just have to bite the bullet and take it to a shop hopefully this week.
I did however notice something. When i get to 3krpm ans the boost kicks in until it hits just under 4k rpm. When i hit the 4k rpm the car does a loud pop noise from the exhuast (this is just as thr boost cuts out) and  the check engine light comes on for about 2 to 3 seconds and then turns off again.
Thanks guys for all the replys
The new photos are wrong.
Somehow you have hood the boost T up between the wastegate actuator (which is correct) and the vent line back into the turbo inlet (which is VERY wrong).
You now have absolutely NO boost control.
The loud pop at 4k is when your car is hitting boost cut.  The ECU is killing it.
The boost T's second side needs to be connected to the nipple on the turbo outlet.  That's either on the turbo outlet pipe (to the intercooler) or directly on the compressor housing (there are a couple of options depending on the car - Nissan did it both ways).
Thanks mate i will try that. I can see the one your talkong about that goes from the tirbo outlet pipe so i will connect the turbo boost tee to that on the turbo side nip.
Where does the turbo inlet vent line go to?
Hey @GTSBoy and  @Robocop2310 thank you so much for your help. It turns out the vacuum lines were all wrong. I connected the turbo outlet pipe vac line to the boost tee and just blocked off the turbo inlet vent line off and the car seems to run perfect now. It still seems like the boost kicks in around 3k but it doesnt cut out anymore and feels much smoother.
GREAT WORK!!! Happy ending.
  • Thanks 1
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
